Postby Aaron » Tue Feb 25, 2014 5:57 pm
Well I bought a Yamaha F9.9AE High thrust four stroke outboard, and suprise suprise it didn't fit! We were expecting that and made some modifications.
I recon now a 2 stroke 20hp could fit with out a problem.
I have also removed the U-shape chainplates that were old and really hard to get to, so now im making a stainless strap for the back stay, Just running the one wire, and is also easy to see the conditions of the nuts and bolts.
This photo was taken before the reconstruction but ill put up more when its all painted and looking pretty.
The boat didnt fit motor............
Cheers Hatters,
Dawn Breaker
Aaron
Images: 2
Postby SeaLady » Tue Feb 25, 2014 8:34 pm
Aaron.
I am going to slap you.
Where is my invitation for a sticky beak.
You have seen Sea Lady.
Only fair!!!!!!!
Postby Phillip » Wed Feb 26, 2014 7:31 pm
Aaron,
You are going to fiberglass in around that hole arn't you?
You will get fumes and water in the boat otherwise!
Postby Aaron » Thu Feb 27, 2014 4:02 pm
G'day Hatters,
Yes Phil, I made in fills out of 3mm plywood that follow the outline of the cockpit and transom. (Its hard to explain but ill take some more pics next time).
Im leaving the v in the transom like a bucket with a hole in it to allow water to escape and keep chain in there so no low life nics my motor!!!
The plywood is glassed in with 2 layers of 450 gram chop stand, with bog on top to take up some volume and a thin layer of woven mat with micro balloons on top for easy shaping, and then it will be painted. Im enclosing the whole lot, thats why the chain plate had to be moved, to allow access. The only bolts i'll struggle with are the push bit bolts.
Yes well Diana, We hope to be motoring soon! so you might have to come and visit her on Sea Lady as I cant see Dawn Breaker going to sea anytime to soon. I think we are harbor bound for a while. It would be great to show you the boat that you told me about that turned my dream into reality.
Aaron
Aaron
Images: 2
Postby longdeepthinker » Fri Feb 28, 2014 11:26 am
Hi Aaron,Best of luck with your Tophat refurb.I am wondering if the motor you have purchased is the new current model?
Thanks a lot,
John.
longdeepthinker
Postby Aaron » Wed Mar 05, 2014 8:28 am
G'day John,
I bought it off Gum tree, its a F 9.9 AE which is from what I've researched a late 80's to mid 90's model, but its down bugger all work.
I don't think they make High thrust Yamaha's anymore, and one thing I remember from all my research is the ultra longshaft 9.9 which I really wanted was only a electric start, which i don't think is a cool thing when it lives out side and is quite close to the water.
My F9.9AE is electric and rope start which is good.
Aaron
Aaron
Images: 2
Postby SeaLady » Wed Mar 05, 2014 6:14 pm
Bought a new kettle.
Small - 500ml sufficient for 2 cups of coffee.
Handle folds down.
So I can fit the kettle and the breakfast frypan on my double metho stove at the same time.
Hopefully it will boil more quickly as well.
When this Sea Lady wants her morning coffee.....
SHE WANTS HER MORNING COFFEE!!!!! 8-)
Postby Troppo » Wed Mar 05, 2014 6:26 pm
Coffee? This is what I call a camping coffee maker: http://www.coleman.com/product/camping-coffeemaker/2000003603#.UxbfW_mSyWk
Where did you get the 500 ml kettle? I only see the 2.5+ litre ones.
Postby SeaLady » Wed Mar 05, 2014 10:04 pm
Purchased from one of those fancy kitchen shops, that charge like wounded bulls.
Postby Phillip » Wed Mar 05, 2014 10:33 pm
So troppo,
Is that coffee maker for real?
If it is.. whats another $50, gotta have one :mrgreen:
Users browsing this forum: No registered users and 42 guests
