Bow Repair ?
Re: Bow Repair ?
Postby bearmcnally » Sun Feb 02, 2014 5:46 pm
Brad ,Remember everything is fixable ? ( A structural Engineer told me this ! ) Forget the expoy ! NEED a photo of the damage ? You cannot just stick it back together ! So forget the epoxy solution .
Regards Bear
Re: Bow Repair ?
Postby Brainless » Mon Feb 03, 2014 6:02 am
I'm not overly familiar with Pittwater but if there is a good public wharf you can tie up on for a few hours I would suggest doing the work from it
Regards
Ryan
Images: 99
Re: Bow Repair ?
Postby Aaron » Mon Feb 03, 2014 8:19 am
G'day,
If its just a scrap and took gel coat off and the glass is exposed my advice would be, fire up the grinder and buzz the inside of the hull and lay up glass from that side and just fill the scrap with bog ( Plastybond is the best! grab it from bunnings ). If its not that bad just fill it with bog. By the sound of things it did no structual damage and remembering the hull is about 5-7mm thick aswell id just fill it. Plastybond goes off in 10 minutes.
Good Luck
Dawn Breaker
Mk11
Aaron
Images: 2
Re: Bow Repair ?
Postby DESIREMK1 » Mon Feb 03, 2014 6:21 pm
Hi Brainless ,
I have been considering just as you suggest mate , though with all the Environmental Legislation that exist today , the financial penalties that exist for such breaches , should have an owner more then weary !!!
Much Appreciation to all that have given advice , all have equal bearing in my mind !!!
Brad
DESIREMK1 .
DESIREMK1
Images: 4
Re: Bow Repair ?
Postby DESIREMK1 » Sun Feb 09, 2014 7:20 pm
Hi Guys / Gals ,
I was onboard our Mk1 today , after a hectic week at work . Its funny how a persons recollection of damaged sustained in an incident can be worse , than the physical damage sustained .
Brad
DESIREMK1
DESIREMK1
Images: 4
Re: Bow Repair ?
Postby Troppo » Sun Feb 09, 2014 8:17 pm
Hi Brad, does this mean you still have no photographs?
Re: Bow Repair ?
Postby DESIREMK1 » Mon Feb 10, 2014 8:00 am
Hi Troppo ,
I cant resize pictures that well on my Galaxy phone , though i have good ones to post after i resize on my Notebook Computer . Maybe a couple of days ...
Also busy at work ...
Brad
DESIREMK1
2014-02-09 22.08.46.png (325.84 KiB) Viewed 8365 times
DESIREMK1
Images: 4
Re: Bow Repair ?
Postby Phillip » Mon Feb 10, 2014 10:07 pm
Dosen't look to bad from that angle Brad.
Re: Bow Repair ? Get a professional to do the work
Postby SeaLady » Tue Feb 11, 2014 2:45 pm
Get a professional to do the work.
I have learned that the money spent getting a professional to do this type of work is money very well spent.
Yes it costs.
But...............
My shipwright is
John Ashton - Martin
Ph 0418 285 131
or 02 4377 1155
or info@hawkesburyrivercharter.com.au
He lives in Spencer - just up the river.
And his workmanship is fabulous. He is a perfectionist.
His availability will depend on what other jobs he has going.
Re: Bow Repair ?
Postby Phillip » Tue Feb 11, 2014 10:36 pm
Posting the photos for Brad.
Brad's Mark 1. DESIRE
The Damaged Bow 1.
The Damaged Bow 2.
