TOP HAT HULL
TOP HAT HULL
Postby bearmcnally » Thu Jul 05, 2012 6:35 pm
The Top Hat hull Is ONE PIECE ! REPEAT ONE PIECE ! The mould is in halves or 2 pieces .Once the yacht is molded in one piece no joints ! one piece .The mould is separated again , other wise you cannot get the yacht out of the mould because the hull has a little bit of bussel in it . Then the deck and cockpit ,one piece! ,that makes 2 pieces ? add one more for head liner and what ever for furniture !!
NO MORE TALK ABOUT THE TOP HAT HULL BEING MADE IN 2 PIECES AND STUCK TOGETHER .IT'S ONE DAM PIECE !!!!
BEAR GGRRRRR
SPLIT MOULD AND ONE WHOLE BOAT
Re: TOP HAT HULL
Postby Troppo » Thu Jul 05, 2012 7:51 pm
I gunna be making my hull into two pieces if I not careful :roll: . Hopefully fix it before I bust it more.
Re: TOP HAT HULL
Postby surrealbass » Thu Jul 05, 2012 8:21 pm
we need a [Like] button on this here group :D :D :lol:
Chris
Joylee
surrealbass
Images: 17
Re: TOP HAT HULL
Postby Dolphin » Thu Jul 05, 2012 9:14 pm
Oh Bear I don't think so!
I can definitely see a joint in the stem and transom. They're definitely 3 part hull.
:P
Troppo. My wife does a lot of 1000 piece jigsaws, if you keep it below 1000 pieces she can help you put it back together. BTW she is on holidays for 3 weeks if need be. :lol:
Re: TOP HAT HULL
Postby bearmcnally » Thu Jul 05, 2012 9:40 pm
Dolphin wrote:Oh Bear I don't think so!
:P
Oh Mr Greg ? that line you see is the joint line where the halves of the mould are joined and poorly prepared by the builder ! I guess it is a Mk 3 !!!!! :lol:
Re: TOP HAT HULL
Postby storm petrel » Thu Jul 05, 2012 9:57 pm
Perhaps that join comes from using a chopper gun instead of hand laying the glass? I do not know where the two part hull thing came from either. The joint is between the deck and the hull and that is the one that can leak if glassed poorly.
Re: TOP HAT HULL
Postby Wild Rose » Thu Jul 19, 2012 8:08 am
Your just trying to trick us, bear.
thats not a top hat coming out of the mould !!! or do they stick the keel on after making it a three piece hull ???
:D
Dave & Rosie
"Wild Rose" Mk II
Geelong Vic
Wild Rose
Re: TOP HAT HULL
Postby Ianb » Thu Jul 19, 2012 11:09 am
Of course Bear is totally correct. The join line you might see is what is called "flash"in plastic moulding, where a little bit has leaked out between the molds. You could make a hull in two pieces, but then you would have a weaker structure unless you went to a lot of trouble to reinforce the join. Why would you bother?
The lead inside a moulded keel is excellent in an old boat. Bolt-on keels are a worry for an old boat, and fixing/replacing keel bolts could be more expensive than the boat is worth.
Re: TOP HAT HULL
Postby bearmcnally » Fri Jul 20, 2012 8:41 pm
Hey Ianb look what I found ?
top hat mould.jpg (8.88 KiB) Viewed 10356 times
Re: TOP HAT HULL
Postby Phillip » Thu Oct 11, 2012 10:00 pm
GGRRRRR
I wasn't going to admit it but I was the one who said two parts to the hull, at least for Mark 2 & 3's.
:mrgreen:
Here's the proof!!!!!!!!
:D
From Seacraft C. 1976
