Rudder removal
Rudder removal
Postby Brett2016 » Wed Feb 06, 2019 5:50 pm
Come April I will be lifting San Felice out for a scrub. I am looking at changing the bushes on the rudder and wondering how much clearance under the keel I will need to drop and remove the rudder?
Cheers, Brett
Brett2016
Images: 1
Re: Rudder removal
Postby Phillip » Wed Feb 06, 2019 10:59 pm
A minimum of 800mm.
Best to remove inwater if you can and get towed to your haul out place.
Also consider replacing the cutless bearings top and bottom in the rudder tube as any flop in the rudder is caused by these 2 bearings.
Re: Rudder removal
Postby Brett2016 » Tue Feb 12, 2019 2:06 pm
Thanks Phillip. Sorry for late reply just got back from Hobart wooden boat festival
Brett2016
Images: 1
Re: Rudder removal
Postby Phillip » Tue Feb 12, 2019 8:50 pm
Brett2016 wrote:Thanks Phillip. Sorry for late reply just got back from Hobart wooden boat festival
:mrgreen:
