Ripple Too gets some loving
Postby Boydie » Tue May 29, 2018 4:02 pm
I posted a while back not long after we purchased Ripple Too about some of the first jobs I did on Ripple Too however the post appears to have been lost when the forum had some issues, so here is a recap.
My wife and I purchased Ripple Too in early Feb, I sailed a lot when I was younger and had not owned a boat for many years, and never a full keel yacht.
We bought Ripple Too 'as is where is' knowing it needed a fair bit of maintenance to bring her up to speed but she appeared to be solid, had a bunch of spare head sails and having been raced as RANSA at some point and was well equipped with all lines back to the cockpit which would make sailing with Lisa who was new to sailing easier. After no end of confusion and messing about with RMS we managed to transfer the boat and the mooring into my name and set out to start tacking some of the jobs
The first job was to clean out the bilge which contained approx 30 liters of water (mixed with oily muck) which had come from the (now removed) water bladder thanks to a hose which rubbed through on the engine fly wheel. The water was too dirty to pump out into the harbour with the manual pump so I headed over to Withworths to pick up some oil absorbers to separate the oil form the water and headed over to the boat.
This is where it got a bit more exciting, Ripple Too came with two old fibreglass dinghys one which was used during the boat inspection leaked like a sieve (albeit the better looking one of the two) and the other was just plain ratty. Knowing I would be a while I choose the ratty dinghy and rowed out, I reached the boat and tied off, went to stand up and got my toes jammed in the cut up pieces of milk crate that had been used to reinforce the dinghy and I fell backwards on my back like a turtle, spilling oars and cutting my feet up in the process. After regaining composure (to the delight of the local fishermen) and paddling around collecting the oars I successful clambered aboard.
Feeling rattled i removed the engine covers and deposited the oil absorbers into the bilge and settled down to wait while they worked their magic. While the absorbers did their thing I opened up the switch panel to start to diagnose the reason why the automatic bilge pump wasn't working. Greeted by a rats nest of 7 core trailer wire and wires twisted together with electrical tape I realised there would need to be some surgery done to get the bilge pump working and pass the insurance inspection. Back off the boat I managed to get to shore and return to Whitworths and purchase a new bilge pump, switch and wiring.
Back on the boat without further incident I checked the bilge to see if the magic had happened. The absorbers were full of water and oil, nothing was separate, this wasn't going to work. Rummaging through the boat I found some buckets and a bunch of old oil containers, ringing out the oil absorbers into the bucket and decanting into the containers was time consuming and messy. I needed a better solution, more rummaging turned up a mop head and a pole with a magnet attached for retrieving tools from the bilge. I now had a sponge on a pole which sped the process up. After filling the stockpile of bottles on onboard I still had water in the bilge, as luck would have it the milk crate dinghy was also reinforced with old oil containers, so after extracting these I managed to empty the bilge and install a new pump and sort out the wiring for the small solar panel. Feeling pretty beaten up I collected up the oily water and mess and returned to home (bottles were taken home and disposed off responsibly).
The following weekend I returned to do a general clean up with the slipping date and survey fast approaching. There was a solid southerly blowing and from the shore it was easy to see the boom cover was in tatters and the weather strip in the Genoa was partially flapping in the wind. After getting to the boat I wrestled the sails off and packed them out in the dinghy including the stockpile of spare sails. A visit to the sailmaker the next week saw the weather strip resewn and a new boom cover made.
A quick tip out a few weeks later saw the sails back on and some final prep for the slip and survey, still haven't been for a sail.
Survey day came and the guys from Gladesville marina picked her up and took her to the slip while I was at work (just across the river). A phone call at midday suggesting I should come for a look before the antifoul went back on revealed this
499
The old antifoul had washed completely off with the water jet leaving a messy looking hull, advice was that she would need a full strip next time as the paint may not stay on. Also found a dozen or so osmosis blisters which would need some treatment.
The other surprise was the bow fitting had lifted, after reading a lot of forum posts I worked out that this was becoming common and I would need to remove the fitting, the wet wood and sort out some better support
500
The survey inspection was completed and passed with only comments on the steaming and mast head lights not working (mainly because they were wired with trailer wire) I left feeling OK about the boat but had a growing list of jobs.
Fed up with the two crappy dinghys I bought a new inflatable tender and went sailing with my Aunt who was visiting from Denmark, the day out on the harbour was great and the little boat sailed perfectly, I was well impressed.
501
On the way back we came across an issue with the little Sole Diesel, it seems she has a lot of blow by and sprays vaporised oil throughout the engine bay when hot. This resulted in the motor getting low on oil, stalling and not starting again on approach to the mooring. Luckily enough I still had sails and after a couple of circles successfully sailed onto the mooring which was nerve racking but got us out of a pickle.
502
Another sail with some friends a couple of weeks later confirmed that the engine was OK as long as the engine oil levels were kept up, the film of oil persisted and was a proper pain in the arse though and after talking with an engine builder friend it was agreed a overhaul was the only way to solve it. The engine needed to come out.
With a growing list of things to do I started calling around the dockyard on the harbour to see if I could get a spot on the hard to do some work over winter, Woolwich was the only place that was happy to have DIY but at $200/day and a 3 month waiting list it wasn't feasible. After speaking to my Father who has a property in the Hawkesbury and a few transport companies we decided that Ripple Too should have a holiday on the farm which would let us complete a proper refit for hopefully less $ than having work done by the local dockyards. Some proper yacht stands were purchased (I didn't like the idea of a 3 tonne boat falling on someone because I propped it up with scraps of timber) and plans were made.
So with everything booked I headed down to Ripple Too after work one evening, stripped all the sails for a second time, removed the running rigging, the boom and loosened the standing rigging a little ready to be hauled out the next morning. I slept on the boat and got up nice and early to run around to Woolwich Dock. On the way I got a call from the transport company letting me know I wasn't booked in for a lift that morning (something went wrong on their end). I turned up and after some discussion I was given the first lift as luckily they had a spare spot.
All good I had a lift and a truck, I didn't need to go back to the mooring and plan this all again, until the question "so you have the mast down already don't you", no was the answer, I had booked the crane to lift it out, "well that wont happen today, the crane is broken". Awesome!. After a bunch of discussions a new plan was devised, I was tied up in the travel lift dock and with a group of dock hands recruited the mast was lifted straight out of the boat by hand and disappeared over my head onto the hard.
503
Up next for Ripple Too was a ride in the slings, a ride on a truck and then a ride on a 200t slew crane (franna broke down on the way to the job) and we were finally on the hard.
504
505
506
So there she is high and dry ready for a refit.
For those that are interested, moving Ripple Too both ways works out equivalent to about 12 days on the hard at Woolwich, With her at home, I can take my time, have an extra set of hands and my Fathers opinions and workshop to help me along.
Anyway, that was a long post, you are up to speed and I will keep you posted on progress as we go.
JB
Boydie
Images: 28
Re: Ripple Too gets some loving
Postby Phillip » Tue May 29, 2018 10:23 pm
Well done JB, top marks for persistence, you will enjoy her all the more when back in the water!
Postby Sailtime » Wed May 30, 2018 12:52 pm
Hi - I had the same engine. I've sent you a PM.
Shea
Sailtime
Postby Troppo » Wed May 30, 2018 4:20 pm
Great story, JB.
That is a fantastic idea moving your boat to somewhere you can work on it more leisurely. Once you have done the work and are back on the water I am sure you will greatly enjoy having a boat in really good shape.
Postby Boydie » Sun Aug 05, 2018 7:16 pm
Time for an update
After getting Ripple 2 home the first job was to get the old Sole Mini 3 out, after a lot of boat yoga, some creative use of the block and tackle, some strategic use of the reciprocal saw she was on the ground.
521
522
The original plan was to recondition the old motor and put it back, after a good look at the auxiliaries it looked like along with internal bits I would need a starter motor, maybe a alternator rewind (full of oil), probably a fuel pump and injector, plus who knows what else. So this is the old diesels final resting place, unless she can get a gig as a pump motor on one of the farms around the place.
After the donk was out a general strip out started along with the list of dumb things found aboard:
Dumb thing 1
515
514
513
We thought this was an anode that had been antifouled at first, but no, it is a bung installed through the hull into the bilge about 100mm above the bottom of the keel, screws were completely rusted out and all that was stopping it becoming a self sinking device was a scrap of silicon. Fitting sent to the bin, hole to be glassed up.
Dumb thing 2
516
240V power point used to 'wire in' the cig socket in the V berth, also in the bin
Dumb thing 3
519
Guess the head was never flushed, waste fitting was capped off inside the hose. We have decided to remove the pump out head in favour of a porta pottie. Surveyor wasn't too happy that there was no holding tank and I'm not keen taking up space installing one, nor dealing with pumping it out.
Dumb thing 4
518
517
Drinking water filter used as a raw water filter, was very blocked, also in the bin
After a false start I final found a stripper, Kris from DK Soda Blasting came and stripped the antifouling in about 2 hrs setup to pack up, saved me weeks of sanding and did a top job.
523
524
525
526
All stripped a small amount of new osmosis was ground out along with a bunch of questionable existing repairs. The good thing about having Ripple Too at Dads is that she can have a good dry out before glassing up again
Next job was digging a hole and pulling the rudder out.
527
Dumb thing 5, shoe bedded in a huge chunk of silicon and only 2 bolts actually through the hull
532
After thinking far too much about how to provide engine power to Ripple Too Dad offered me his old long shaft 8hp Tohatsu that had been in the shed for the past 20 years. So we cut a big hole in the boat and had a test fit, mostly good, may need to move the bilge pump outlet. Motor is now at the mechanic to try and get it up and running again, watch this space.
529
531
530
For the last month we have really just been sanding, stripping fittings and filling holes to try and stop the leaks
520
Photo of the mast girder and the heap of silicon that used to be under it
Hopefully there will be some parts going back on next update instead of things being taken off...
Josh
Boydie
Images: 28
Postby Phillip » Sun Aug 05, 2018 8:41 pm
Well done Josh, keep up the good work!
Postby Shaun » Mon Aug 06, 2018 5:58 am
Fantastic work Josh, have you considered a small slot cut-out up the transom to allow the OB to be tilted?
Postby Troppo » Mon Aug 06, 2018 7:20 am
I love your story, Josh. Reminds me of when I was working on Windchaser.
And I don't know why you got the hull soda blasted, I only spent about two weeks sanding mine. Just because my arms nearly fell off from working the sander for days and I actually did fall off the trestles around the boat doesn't mean it was hard to do or anything. . . . But come to think about it, soda blasting sounds a better option.
I'm waiting with interest for what happens next.
Postby Boydie » Mon Aug 06, 2018 5:20 pm
I hadn’t thought about making a cutout in the back Shaun, would make keeping the outboard out of the brine easier, will need to look into that.
Haha Troppo, I would still be sanding now and would look like a smurf at work on Mondays. Getting it blasted was certainly the easy less mess option.
Thanks for your encouragement, nearly at the put it back together phase
Josh
Boydie
Images: 28
Postby Shaun » Mon Aug 06, 2018 8:13 pm
Here is a link to Atomvoyages, who has done the outboard motor conversion on many boats https://www.youtube.com/user/atomvoyager/videos , just another thing to add to the list to think about with the refit,
