Climbing the mast
Re: Climbing the mast
Postby ChrisB » Sun Apr 15, 2018 12:53 pm
For those with steps attached to the mast....how many do you have?
ChrisB
Images: 1
Postby Phillip » Sun Apr 15, 2018 5:41 pm
I'll count em' tomorrow for you
Postby Phillip » Mon Apr 16, 2018 5:49 pm
2 together at the top so you can stand and work.
Total above spreaders is 8
Total below spreader is 10. Four of which are folding, 1 below the spreader and 3 at deck level to get past the boom.
So, 14 stirrups [Whitworths 50542N ] and 4 folding [Whitworths 50955] total $337
You will need 80 monel 4.8mm rivets ww36648 $79.60
A heavy duty pop rivet gun such as ww65516 $75 Don't try and use a household pop rivet gun as you will get into trouble, monel rivets are very hard to pop.
All joints between steps and mast must be painted [do it on stirrups not mast] to prevent corrosion. 1 x Duralac jointing compound ww59733 $35.
So you are up for $527
I did mine in three stages and when I had finished I just wished I'd done the lot when I had the mast out. I think I spent over 8 hours up there doing it :evil:
The mast above the boom
Folding steps below the boom
Postby ChrisB » Thu Apr 26, 2018 9:19 pm
Thanks Phillip....a comprehensive answer!
ChrisB
Images: 1
Postby ChrisB » Thu Oct 18, 2018 7:16 pm
Well it’s taken sometime but at last I’m ready to start on my mast steps......thanks for the inventory list Phillip.....just one last question....how far apart did you space your steps?
ChrisB
Images: 1
Postby Phillip » Thu Oct 18, 2018 8:18 pm
When this weather improves I'll measure it for you.
As I did it in three stages it sort of just came together. :roll:
Postby Phillip » Wed Oct 24, 2018 9:28 pm
mast steps for Top Hat.jpg (758.67 KiB) Viewed 8451 times
This diagram should answer some of your questions :D
Postby Lord Chunderguts » Wed Jan 20, 2021 10:07 pm
Hello chaps, I'll be adding mast steps soon, as per Phillip's instruziones, can the spreaders be used as part of the mast steps, are they super strong, or is it a grotesque offence to apply downforce onto a part only designed for lateral loads? Thank you, -Will
Lord Chunderguts
Postby Phillip » Thu Jan 21, 2021 7:28 am
Its OK BUUUUT no jumping up or down or down you will go!!!!!
Postby Lord Chunderguts » Thu Jan 21, 2021 10:35 am
Thank you Phillip, shall make sure never to bring my pogo stick when going topsides.
Lord Chunderguts
