- 20160915_170515_resized.jpg (267.21 KiB) Viewed 10063 times
Finished a couple of projects today.
One, re-wiring and new switch panels, with a simple volt meter for each battery. I tucked the master switches inside a locker (yes i know one of the switches is massive over kill, but it was what i had on hand) . Put appropriate fuses on each circuit.
The re-wiring took a lot longer than i thought it would. The new wires started being quite neat, but gota little messy towards the end, but much better than it was.
- 20160915_145054_resized.jpg (212.52 KiB) Viewed 10063 times
- 20160915_170552_resized.jpg (361.53 KiB) Viewed 10063 times
I'm hoping the second one will solve one of the problems of an outboard on the transom. ...lifting the outboard froma dinghy or onboard to the bracket, so fabricated this hoist .
- 20160919_112919_resized.jpg (350.25 KiB) Viewed 10063 times
