Finally got around to completing this repair!
Was a lot more time consuming than I thought it would be, didn't help doing it on the mooring, holding onto the boat with one hand and working with the other!
You was right Frank, using cloth didn't work, too many air bubbles left behind it, so I ripped it out before it set. Used Bote-Cote epoxy mixed with their easy-sanding filler, then painted 2 coats of 2 pack undercoat, & 2 coats of Norglass 2 pack top coat.
- toerailground.jpg (34.43 KiB) Viewed 6243 times
- toerailprog.jpg (299.7 KiB) Viewed 6243 times
- toerailfinished1.jpg (272.62 KiB) Viewed 6243 times
- toerailfinished.jpg (366.34 KiB) Viewed 6243 times
