ubolt
ubolt
Postby rob.lovelace » Thu May 10, 2012 5:40 pm
the U bolt to the chain plate that the rigging attaches to.
Are they a production part? if so who makes them?
or are they a custom fabrication?
I have some that have been replaced and they were the wrong size and seem to be bent in so they fit. All a bit shabby and I want to replace them.
Rob
Sundowner
Westernport
Re: ubolt
Postby bearmcnally » Thu May 10, 2012 7:52 pm
Rob the original U bolts might have been Riley's or Fico or similar. Ronstan do make them but they might be slightly different . I do know through experience ,metric and imperial plays a bit of a problem with sizes even these days .
Re: ubolt
Postby rob.lovelace » Thu May 10, 2012 8:41 pm
thanks Bear Ronstan rep said they don't carry anything like it and I couldn't find them in the current Riley's catalogue I'll check out Fico.. Rob
Re: ubolt
Postby Tales » Thu May 10, 2012 8:47 pm
Hi Rob,
Just had a look at your pictures for the Flemming installation and your 'U' bolts look like the standard MkII/III issue to me.
They do have an industrial look I must admit but they really are good things.
They have rolled threads (which is good) and the one I removed last year from Tales showed no sign of corrosion at all.
Can you post a pic?
Re: ubolt
Postby rob.lovelace » Thu May 10, 2012 9:27 pm
you can see the bent one on the left in the second picture, it is a M10 (metric) the original ones are 3/8 whitworth. about 52mm centre to centre. The Uppers are about 102mm centre to centre. All of them are made on the same angle to suit the rig.
Re: ubolt
Postby Tales » Thu May 10, 2012 9:46 pm
Yeah, you're right mate, it's a ring-in.
There is another thread about 'U'bolts on this site (see below) and Mark had some spares available.
Re: Chain plates
by storm petrel » Fri Aug 05, 2011 4:02 pm
Yes I have a few spare chain plate U-bolts, if you need one.
Storm Petrel
Re: ubolt
Postby rob.lovelace » Wed May 16, 2012 7:40 pm
thanks Mark, From myself and Sundowner .
