Power tools
Power tools
Postby Miker » Wed Dec 02, 2009 2:57 pm
Ok, so there I am on Sunday sanding away by hand thinking "there must be a better way". So, what do you all do to remove old varnish, clean greying timbers and ready it for a new coat of varnish or oil?
I've thought of getting an 18volt Ryobi detail sander, or even using a small generator to run the 240volt sander. Any other suggestions?
Oh, this is to be done on the mooring, not on a work berth with 240v power.
Michael,
Re: Power tools
Postby Phillip » Wed Dec 02, 2009 8:56 pm
Evening Mike,
I have been looking at an inverter but don't really know enough about them.
Like what wattage or how much battery power is needed.
I have and use a 12 volt drill and a 12 volt vaccunm cleaner.
All else is done by hand! :)
Re: Power tools
Postby auriga » Wed Dec 02, 2009 9:10 pm
My boat has been a floating bunnings for quite some time.. ive found that using a battery powered sander is a good option, we got a combo pack (sander , jigsaw, drill, torch) from aldi for <$100 with two battery packs that has served us well
no point in spending big bucks if its going to live onboard as the salt will kill anything in a short period of time (ours is still going strong after 12months!)
dan
auriga
Re: Power tools
Postby Shaun » Thu Dec 03, 2009 7:17 am
Hi Michael,
It's a daunting task, but between beers the job is not too bad!, & the rewards are satisfying.
The foam type sanding blocks are very good to get to areas the machines can not, also for a light sanding between coats which is essential to remove fine timber burrs.
Ive become a fan of hydrochloric acid :roll: , which instantly turns greying timber to beautifully new timber, but obviously its very dangerous stuff, will damage some plastics too, use sparingly & a good job for a rainy day. Not sure how it goes removing old varnish??
:arrow: Is it possible to re-charge the cordless battery packs from the 12v cigarette lighter plug on the boats?
Re hydrochloric acid
Postby olly » Thu Dec 03, 2009 2:19 pm
Hi Shawn,
was wondering about the details of using this stuff. It was used on the topsides when i went in for an antifoul and they came up beautifully. But how and where can you use it otherwise - the dilutions, hazards etc
Thanks,Olly
olly
Re: Power tools
Postby Miker » Fri Dec 04, 2009 9:16 am
Thanks for all the replies,
I ended up going to Bunnings, I bought a Corner Cat sander for $62, two more 18volt batteries for $98 and the requisite assorted paper. I now have 4 18volt batteries because I have the cordless drill as well. When testing the sander, it actually works better than the Ozito (chinese for elcheapo) detail sander I bought a year ago.
I like the idea of hydrochloric, but not the idea of spilling it. I'm a clumsy ass these days. So I used some nice teak cleaner with a brush and will now sand with power. :D \
Once I have a play on the boat tomorrow I'll update with photos of before and after if I get the chance.
Now, a 12 volt vacuum cleaner, there's an idea!
Michael.
