Postby Phillip » Tue Apr 15, 2014 9:31 pm
No need Bill,
As it was worn out I rebuilt it! :D
Postby Phillip » Thu Apr 17, 2014 9:54 pm
Well we are on the home run.
Yesterday the deck gear fixing holes were drilled.
And today I installed the new deck winch. Will add the rest of the gear when I get help. [Arms aren't long enough!!]
:D :D :D
Tomorrow [Friday] undercoat in the main cabin or install deck gear or polish deck.
Postby bornfreee » Fri Apr 18, 2014 7:18 am
Hope you got a pad under that winch Phil :D
bornfreee
Postby Phillip » Fri Apr 18, 2014 9:09 pm
Today the deck gear went in. Here's longdeepthinker working hard on the cabin roof! Many thanks John.
Here is the result. Note: two reef lines a vang and tack downhaul to go in when the boom returns.
Also did the undercoat to the cabin. Took three hours to do.
This worked a lot better than before. No sunlight coming through the paint now!
So, a final top coat then the varnish and all the painting will be done!! :D :D :D
Postby Phillip » Sun Apr 20, 2014 10:38 pm
Getting there!
Postby Troppo » Mon Apr 21, 2014 8:05 am
You have accomplished a huge amount of work Phillip. Incredible.
What paint are you using on the interior?
Postby longdeepthinker » Mon Apr 21, 2014 6:07 pm
Cool deckhand,cool boat tied up alongside.Lucky to get such highly skilled help these days!!!!!
longdeepthinker
Postby Phillip » Tue Apr 22, 2014 4:16 pm
Thanks JM :D :D
Louis, I'm using Norglass Shipshape Epoxy in the exposed areas inside and Norglass Weatherfast gloss enamel in the lockers.
I am not painting the exterior, [this time ?]
Remember this paint job was started last October to overcome the mould problem I HAD.
Seems to have got a little bit out of hand!! :shock:
But happy so far with all the results, including the paint job! :D
Postby storm petrel » Tue Apr 22, 2014 5:33 pm
Very nice job Phillip, makes us all look a bit slack in the maintenance department. I am sure the new interior paint will keep the mould at bay and give her an extra knot at least!
Regards,
Postby SeaLady » Tue Apr 22, 2014 6:00 pm
Met up with Sonia "Curly Tops" and Dave - "ex Peppercorn" over Easter.
So 3 boats rafted up together for French champagne and bbq.
Raspberries to those who decided not to join.
More yummy bubbly for us. 8-) :lol:
