Topi,
The SS cover strip on the Mark 1's appears to be made out of sheet Stainless Steel.
You will need SS sheet that is 0.9mm thick [a little bit thicker than 1/32". 0.11mm extra to be exact]
Or what ever close thickness they do today, but not heavier.
The lenghts cut are around 6' 0" [1850mm] long. width of a sheet? And 2" [50mm] wide.
A sheet metal shop should be able to pre-bend them for you in the U shape.
Originally these were fixed in place by roved over 5mm SS [or maybe bronze] rod, about every 2- 300mm,
but today it may be easier to fix with nuts & bolts.
- Mk1-Toe-Rail.jpg (75.61 KiB) Viewed 8128 times
- Mk-1-Toe-Rail-Joint.jpg (105.06 KiB) Viewed 8128 times
Hope that answers your question.
