Bow Repair ?
Re: Bow Repair ?
Postby Troppo » Wed Feb 12, 2014 8:49 pm
Phillip wrote:Brad, how come I didn't get a photo of the barge???
It sank before Brad could click a pic. It was hit by a Mk1.
Re: Bow Repair ?
Postby DESIREMK1 » Thu Feb 13, 2014 5:19 am
In short Phillip , i wasn't going to hang around , as i may have been incriminated !!! . In a few months ill be back in the area , as ill slip our Mk1 at Lovett Bay Boatshed , and i will check on the state of the Cement Barge . The cement Barge may have developed an anxiety , in regard to wayward Top Hats , so ill look into its condition then !!!
Troppo :
The Cement Barge was around 2m X 4m , weighing an estimated 5 tonne , it seems the only way we can really test the strength of a Mk1 , is to gain a volunteer that will lend the Royal Australian Navy their Mk1 for Offshore Missile Range Testing !!!!! :)
Brad
DESIREMK1
DESIREMK1
Images: 4
Re: Bow Repair ?
Postby Ianb » Thu Feb 13, 2014 8:01 am
Perhaps people dont know, but last time I met him, Brad was in the demolition business.....
Back to the practical. Many years ago, when I was doing osmosis rectification, I used epoxy resin to fill the holes, and held it in place with cling wrap under masking tape. The cling wrap left a smooth surface and came off reasonably easily.
Re: Bow Repair ?
Postby Miker » Fri Feb 14, 2014 6:51 am
One thing I don't see posted anywhere,
Make sure you use a wax and grease remover before apply I any epoxy over in damaged gelcoat, otherwise it may not stick.
The cling wrap is a brilliant idea, I use it regularly when fixing dings on surfboards..... Not mine you understand, just my friends,,, :) just make sure when you pull it taught over the epoxy, that you don't get creases in it. Saves on a lot of sanding.
Re: Bow Repair ?
Postby DESIREMK1 » Fri Feb 14, 2014 12:16 pm
Looking forward to having that long awaited beer , with you Ian :))
Sometimes in life it's hard to separate your profession with your passion , in the publics interest , and my duty of care , to the boating community of NSW , i am now considering having this Cautionary Sign onboard !!! ( Lol ) :)
Brad
DESIREMK1
2014-02-14 11.43.38.png (282.47 KiB) Viewed 5538 times
DESIREMK1
Images: 4
Re: Bow Repair ?
Postby Troppo » Sun Feb 16, 2014 9:13 am
Hahehehe :lol:
Brad, great sense of humour.
