Port Lights (Not windows)
Re: Port Lights (Not windows)
Postby Phillip » Tue Sep 24, 2013 9:05 pm
:o
Now Greg, is that a DISCLAIMER!
Don't forget to put a small SS washer between the acrylic and the base to maintain the seal thickness.
Postby Dolphin » Wed Sep 25, 2013 7:21 am
Thanks Phil, that makes sense.
One of the main reasons for the failure is that there is a recess in the frame that holds the Perspex and that was a neat fit for the particular sheet I had. If I had have reduced it 3 or 4 mm it may have worked. In any case though the frame is badly corroded. Just another boating job I guess.
