HELP Replacing Rudder on mk3
Postby dutyfirst00 » Sat Apr 13, 2013 10:33 pm
I need to replace a rudder on a mk3 does anyone plans
Simmo on Marrakesh
dutyfirst00@bigpond.com
dutyfirst00
Re: HELP Replacing Rudder on mk3
Postby Ianb » Mon Apr 15, 2013 6:51 pm
Scroll down in this sub-forum to "Reef Shoe Bearing " post- there is some design info. viewtopic.php?f=6&t=1340
Postby Ianb » Fri Aug 23, 2013 1:10 pm
Phill- Looking at your photo showing dropping the rudder on Seaka, do you have the dimension of clearance required under the keel to allow the rudder stock to be completely slid out of the tube? Would be good to have it for reference.
Postby Phillip » Fri Aug 23, 2013 4:40 pm
Ian,
From memory it's at least 800mm.
I will check my notes and confirm that dimension.
