Chart Plotter Position
Re: Chart Plotter Position
Postby Troppo » Wed Oct 31, 2012 8:03 am
My chartplotter is mounted on a board that swings out on a long hinge but I like the look of the ram mount. It's quite small and tucks away. The board in my setup is large as it also housed a wind meter and depth sounder. The size makes it awkward getting up and down from the cabin. Also, when I got the boat none of the instruments worked so I got a GPS/depthsounder in one unit and stuck it on but it would be better to be more compact like the ram mount.
Postby storm petrel » Fri Nov 02, 2012 9:26 pm
I think the Ram mount will outlast several plotters, so I fixed it to stay.
Postby Shaun » Wed Nov 07, 2012 1:54 pm
storm petrel wrote:
Philip in good conditions, how long does it take you to get down to Pittwater? I am considering heading up your way in January (depending on the appearance of a suitable weather window). If I take a couple of mates we would probably try to sail straight up without overnighting.
Gday Mark,
Going Sth from Camden Haven to Pittwater, I'd leave about 3hrs after a High tide at first light, then your easily in Pittwater the following evening, Ideally I'd look for a solid NE'r that persists throughout the night, so your not bobbing & drifting around on a glassy black ocean . From my very limited experience ive found the Northerly's tend to back slightly overnight, so if you stay on the cautious port tack(as I do) at night, you will be quite a distance offshore at daybreak, & you'll lose some time as you sail back inshore again. Having crew so you can remain fresh would allow a more direct course, staying closer to shore & saving some time. Look forward to seeing Storm Petrel up this way if it happens...although im still hoping to be going Sth to possibly Eden by then..who knows??
Users browsing this forum: No registered users and 7 guests
