Progress with Pelagian
Postby RodM » Sun Sep 02, 2012 10:01 pm
It seems the season to work on boats... I' ve gone over the electrics, including new solar panel, batteries, some LEDs, backup electric bilge pump & tilller pilot ready to go in...
New Solar Panel.jpg (56.28 KiB) Viewed 2549 times
One winch was seized, really only grease gone dry, so both got a clean and a few pawl springs needed replacement. The lower with gears are actually quite exposed to the elements. Its not a long or difficult job, unless you lose something overboard!
Dirty winch.jpg (28.72 KiB) Viewed 2549 times
Clean winch.jpg (27.56 KiB) Viewed 2549 times
The list has grown, as it does, new Fire extinguishers, replace the head pump, major engine service including water pump re-build, some electronics that work, checking anchor & fittings, sheets, revising main sheet system, new main & near new headsail, and fixing the mast head light, for with the old Mastmate was invaluable... But as I can only add three photos, that'll be in the next update.
Cheers, Rod M
RodM
Re: Progress with Pelagian
Postby Troppo » Mon Sep 03, 2012 5:48 pm
Good stuff, Rod. Keep the pics and story coming. With the 3 pics limit, did you know that is only per post not per thread? You can, for example, show 6 pics by doing one post with the 3 pics then another post in the same thread with another 3 pics. But don't stop at 6 pics : ).
