Pushpit
Re: Pushpit
Postby Killick69 » Tue Feb 21, 2012 10:55 pm
Does anyone know what grade stainless steel was generally used for pushpit on Mark3. Was it 304 or 316 grade. How serious is it if one welds 316 using 304 electrodes? and vice versa?
I will try to find out what grade the pushpit is and try to get washers, bolts and electrodes of the same grade.
I removed the pushpit and it is now at home. Both bolts on the Port side had sheared. I will cut all the washers off (lose 6mm on pushpit height) and weld on new washers and bolts. The old washers are 40 mm dia and look to be 2 to 3mm thick. There were no washers on the underside to spread the load, so i will fit decent size washers under and will probably use lock nuts.
Cheers, John
Re: Pushpit
Postby Dolphin » Thu Feb 23, 2012 11:03 am
John, be careful adding big washers to the Pushpit or Pulpit. instead of just sheering off the bolts it might cause damage like that below.
Its like adding bull bars to Volvos with progressive crumple zones. :shock:
Image from Aust Sailng and Yachting Mar 2012.
What may happen with big washers
Bow damage a.jpg (42.51 KiB) Viewed 6618 times
Re: Pushpit
Postby Tales » Thu Feb 23, 2012 12:53 pm
It was the thread which broke in the first place (and it is not uncommon).
It will be the thread which will break next time too.
Re: Pushpit
Postby Dolphin » Thu Feb 23, 2012 1:45 pm
In both cases with mine, and I can only speak from my experience, the weld broke and the stud pulled out of the washer.
Re: Pushpit
Postby bearmcnally » Thu Feb 23, 2012 2:33 pm
Never had that problem on the trusty MK1
Re: Pushpit
Postby Phillip » Thu Feb 23, 2012 3:42 pm
Nor on my Mark 1!
Re: Pushpit
Postby Dolphin » Thu Feb 23, 2012 7:54 pm
But MkIIIs are definitely the fastest. :D
Re: Pushpit
Postby bearmcnally » Thu Feb 23, 2012 8:00 pm
Greg your dreaming ! You definitely have had to much excitement today ?
Re: Pushpit
Postby storm petrel » Thu Feb 23, 2012 8:40 pm
Never had a problem with my trusty Mk11 either!
Re: Pushpit
Postby Miker » Fri Feb 24, 2012 11:12 am
I thought I'd not had a problem, I thought my pulpit was supposed to have a little give, until I inavertantly lifted it and found one of the studs was broken. The break I think was caused by the old mooring practice of putting the mooring line through the v section of the pulpit downtubes, because the anchor was over the bow roller. That's how the previous owner did it, so I didn't know any better. I do now.
It's now fixed with what I think is strong enough to hold a person's weight, but weak enough to not tear the front of the boat off, should anything get caught on it.
