by Tales » Tue Jun 08, 2010 5:28 pm
Peter,
Nick Creech wrote me this when I had a similar query. He is refering to White Tie and the 1978 Solo Trans Tasman.
"The key to drown proofing a Top Hat is to be able to fit really solid storm boards to the windows (I had them permanently bolted in place) and to be able to block the bottom half of the companion way semi-permanently, at least at sea. I left myself only a little crawl hole over a permanent fixture on White Tie, which probably saved her from sinking (got pooped, crash-gybed and partially swamped when she could have filled completely). The lack of a bridge deck is the boat's only real weakness, balanced by the fact that it doesn't have a sliding hatch which is often, itself, a fail point. Not hard to work a positive but removable system. The standard storm boards are a bit of death trap. The taper means they can float out or fall out very easily. If nothing else, they need retaining lines so that you can't lose them altogether."
I had new windows made up for Tales and fitted them a couple of years ago. They are the long one piece ones. They worked fine for a while then started to leak a bit.
Eventually traced it to the cabin roof/deck flexing and making the sealing rubber creep.
The original windows in Tales had an aluminium trim inside with a vertical brace half way along. Now I know why!
Currently making a stainless steel brace to join the cabin top and deck inside the window. Will post details when I finish the installation.
- Attachments
- White Tie in NZ prior to 1978 Solo Trans Tasman
- history4.jpg (44.17 KiB) Viewed 11441 times
