Antifoulling for propeller & shaft
Re: Antifoulling for propeller & shaft
Postby Phillip » Mon May 17, 2010 4:11 pm
I have more info now on PellerClean and it seems that I will get three applications from the tins,
which will work out at about $75 a year. Has a 2 year tin life after opening. 8-)
Seems that to make these prop antifouls work the prop must be turned at speed, to throw the fouling off,
at least every month and more if in a particular foul area as I am.
I will be giving PellerClean a go and will report on its performance later in the year.
Propspeed came in at $170 per application. I couldn't do it. :(
