Austin
Sombrero wrote:Hi all outboarders.
I am afraid I am not a fan of outboards hanging out on the stern. They can be a target for thieves (you might as well leave a shifter and the hand book and spares). They do not work efficiently and quite frankly they look awful, spoiling the classic lines of the Top Hat! .............snipped..........on the permanent bracket. it just hoists up and down when needed and only comes out for service.
John S "Sombrero"
Sombrero wrote:Hi Karl, thanks for your favourable comments. I am proud of the way my boat is set up and I spend a lot of time thinking of and making improvements. I purchased Sombrero with the outboard lowering system already in place. So I take no credit for the idea. When the wife comes back with the camera I will take some photos, but in the meantime I will give a verbal explanation. From my photo as seen by you, you will notice that the pushpit tubework has been added to to incorporate two tubes that run down to where the old outboard bracket was. A new timber bracket with stainless plates bolted to each side with SS tubing a size up on that used for the upright tubes welded to the plates enables the outbourd bracket to slide vertically up and down in and out of the well. I have a single pulley system for each side and holes drilled in the upright tubes to insert pins ( hanging from light line each side) when the motor is lifted clear of the water. Very little effort is required to lift the motor and it sits comfortably down in the well when running. The vertical posts have flat SS plates at the base which are bolted through the cockpit floor. The rest of the tubework is simply pop rivetted to the pushpit. There are two side braces and two running back to the pushpit itself. The tubework does not interfere with getting in or out of the boat, in fact it makes for a handy place to stand on while boarding.
Regards, John S "Sombrero"
