Rudder lower bearing
Postby JeffMaguire » Mon Jan 06, 2025 5:31 pm
Hi there, Just after some guidance on where i can buy the lower pintle bearing/thrust washer. It looks like a flat washer made from nylon or similar. Many thanks all. Jeff.
JeffMaguire
Re: Rudder lower bearing
Postby Phillip » Tue Jan 07, 2025 2:14 pm
Just make one out of a 10mm plastic cutting board Jeff.
Just make sure you have 2x 100mm x M8 and 2x 110mm x M8 SS bolts available
if you have to replace them when you remove the cast bronze rudder shoe.
There is no pressure on this washer, only the turning movement.
Postby JeffMaguire » Thu Jan 09, 2025 8:46 am
Thanks Phillip. BTW I am now the owner of a Mark 1, named Blue Bottle, previously Miss Phoebe. I am trying to get her back into a sailing condition that will satisfy the insurers, new chainplates seem to be the base requirement.
I was also wondering if anyone had a history of the boat? It would be great to connect and chat. Best Jeff.
JeffMaguire
Postby Phillip » Thu Jan 09, 2025 9:44 am
That sounds strange. Better post some photos of the chain plates before you do anything.
I have never heard of chain plates failing on a TH,
Some people have reinforced them, but I don't know why.
Have you done the Top Hat survey?
PS have you joined the Facebook site?
Postby JeffMaguire » Fri Jan 10, 2025 8:55 am
Phillip, not sure where to find the survey? Please point me in the direction and I will complete it. Many thanks. Jeff.
JeffMaguire
