Mainsheet relocation and system
Postby freetasman » Wed Jul 27, 2022 10:27 am
I am considering in moving the mainsheet control from the top of the cabin in the MK3 to just behind the tiller shaft
Also looking into not installing a traveveller and instead using twin sheets arrangement.
I wonder if any members have installed or considered this system.
[https://www.google.com/search?q=twin+mainsheet+system&oq=twin+mainsheet&aqs=chrome.1.69i57j0i512j0i22i30j0i390l5j69i60.13002j1j8&client=tablet-android-samsung-nf-rev1&sourceid=chrome-mobile&ie=UTF-8#imgrc=qGOxQUa6TloQwM]
freetasman
Re: Mainsheet relocation and system
Postby saintpeter » Wed Jul 27, 2022 9:48 pm
But why change something that works well on a TopHat?
My cabin-top traveller is out of the way, has a ball-bearing car with 4-purchase tackle; and I use this as a very important point of adjustment, especially up-wind. The last thing I would want is another set of sheets in the cockpit, tangling with headsail sheets, and requiring one to face aft to adjust. I also use rope bags hanging like saddle bags to the sides of the cabin to keep all sheets, halyards, top/lift, reef lines out of the cockpit. Sorry, no photos tho..
saintpeter
Postby freetasman » Thu Jul 28, 2022 12:16 pm
Because the twin mainsheet will be behind the tiller and the halyards can be stored on both rear corners the cockpit will be more saf and free odf ropes and the bags used for the other halyards.
For me, that have problems with stability in my legs I can't stand up on the cockpit on weather with choppy seas and winds over 15 knots. Having the boom control lower and close to the tiller helps to operate the boat seating without the need to sanding up.
freetasman
Postby Shaun » Sat Jul 30, 2022 12:00 pm
I'm considering a similar setup on my Compass 28, the main con is it can be slow to release the main if you get knocked down, but the pros seem good.
Postby freetasman » Sun Jul 31, 2022 7:41 pm
By moving one of the mainsheet it can be used as a preventer.
I only need to fit on eyebolt on each side plus reinforce that spot because I have a spare mainsheet.
Obviously, extra halyard is needed for increasing the distance.
freetasman
Users browsing this forum: No registered users and 66 guests
