Mark 1 cockpit drain
Postby dism » Thu Oct 13, 2016 10:51 am
Last weeks windy trip north and motoring in the river showed my Mark 1's cockpit drains to nicely work in reverse to half inundate the cockpit floor.
We tried a few at-sea solutions such as rubbish partially blocking the cockpit side holes (making increased pressure against the outside wave slap ingress).
Seemed to work okay but now to do a better fix.
Thinking one way plastic flaps on transom side outlet.
Any others had a win on this or suggestions/pics?
dism
Re: Mark 1 cockpit drain
Postby Miker » Fri Oct 14, 2016 7:44 am
My mark 3 does the same, but only when she's had a clean bum and we've got more than two on board. Apparently, according to Phillip, it's an undocumented feature of the mark 1 and not easy to circumvent unless you post a crew member on the pulpit.... ;)
Postby Phillip » Fri Oct 14, 2016 4:34 pm
It's all to do with the height of the cockpit floor above water level.
Sail fast and the stern of a Top Hat will dig in = more speed! :D
Formit tried to fix the problem by raising the Mk 2 & 3 floors by 100 mm.
It would probably need another 200 mm plus to have a dry cockpit but when you put that
against comfort for the other 99% of the time you use your Top Hat, not really worth worrying about.
I get over the problem by wearing sea boots unless its really warm and calm :D
The more upright you can sail a Top Hat the faster you go, digging the lee scuppers in does not necessarily mean faster!
Postby Iluka82 » Fri Oct 14, 2016 7:58 pm
Iluka has a wooden deck insert that gives about 100mm hight to the floor. I've found this is enough to keep the cockpit dry in most (not all) cases. The deck comes apart in 2 peices to make it easy to remove.
Nick
Iluka82
Postby dism » Fri Oct 14, 2016 8:59 pm
Cheers Nick. Yeah that'd do the trick. Custom build or bought? Any pics/specs?
dism
Postby Iluka82 » Sun Oct 16, 2016 9:32 pm
They were custom built by the previous owner. I found a photo of the inserts when they were out of the boat to be painted. There are 2 pieces that meet where the tiller goes through the floor.
Cockpit floor inserts
Iluka82
