forestay refitting.
forestay refitting.
Postby sgturpie » Wed Aug 17, 2016 8:33 pm
Hi just trying to fix my new Top Hat after a forestay breakage at a top swage point.[1ft from the top point.
Does anyone know how I should get the new forestay up through the furler without disassembling the furler?
sgturpie
Images: 0
Re: forestay refitting.
Postby Phillip » Wed Aug 17, 2016 10:02 pm
What sort of Furler, as they are all different Steve.
Postby Ianb » Thu Aug 18, 2016 10:58 am
sgturpie wrote:Hi just trying to fix my new Top Hat after a forestay breakage at a top swage point.[1ft from the top point.
What happened? Did the mast come down? Sounds like you need all the standing rigging checked/replaced.
Postby sgturpie » Thu Aug 18, 2016 8:59 pm
Phillip wrote:What sort of Furler, as they are all different Steve.
Hi Philip, will find out this w/e .Steve
sgturpie
Images: 0
Postby Phillip » Thu Aug 18, 2016 10:35 pm
Ok, but what have you got keeping the mast up?
Really concerned for your mast now Steve
Postby sgturpie » Fri Aug 19, 2016 11:34 am
using the shroud for the furler at the moment to stabilise the mast, and the shorter ,spinaker lift shroud.
sgturpie
Images: 0
Postby sgturpie » Fri Aug 19, 2016 11:40 am
The forestay was crimped /swaged about a foot from the top. The loose winging of the furler had essentially been swinging freely from the top and therefore broke the forestay just above the swage point.[my mistake, for not keeping the shroud very tight in the first instance]
My task now is to rewire the forestay,either in dock or lift the mast out at Williamstown, probably Hobson's Bay yacht club.
sgturpie
Images: 0
Postby Phillip » Fri Aug 19, 2016 5:12 pm
Steve you will need a rigger, anybody down there with good references from other Top Hatters?
The rigger may be able to do it insitu, ask as you may not have to pluck the mast. :D
Postby sgturpie » Fri Aug 19, 2016 5:22 pm
thanks Phillip, will do.S
sgturpie
Images: 0
Postby Phillip » Mon Aug 22, 2016 4:14 pm
How did you go Steve?
