mark 1 tophat dodgers.
Postby Arohanui » Tue Aug 02, 2016 1:37 pm
Im going to get a dodger made for my TH M1.
Anyone have any pictures, or contacts to get 1 made????
Arohanui
Images: 5
Re: mark 1 tophat dodgers.
Postby Shaun » Fri Aug 05, 2016 3:18 pm
Hard or soft dodger?
Im considering a hard dodger, can put solar panels on it, can collect water on it, use it as boom gallows etc.
Only you need to get the design & build of the hard dodgers right, a lot of ugly hard dodgers out there already don't want to add another.
Postby Troppo » Fri Aug 05, 2016 3:47 pm
Shaun, do you have any sketches of your ideas or pics of made-up ones on other boats perhaps? I have been wondering about them for ages and would be interested in your thoughts.
Louis
Postby Arohanui » Fri Aug 05, 2016 7:44 pm
Im all for a soft dodger with a center zip down screen. There must be people around who custom make these. I also want a zip on it so the rolled up bimini canvass can extend to dodger for complete cockpit shade. With the lifeline screens in cockpit and all this it would almost be a pilot house! I have a vision!
I havent seen any tophat dodgers yet.
Arohanui
Images: 5
Postby Shaun » Sat Aug 06, 2016 7:55 am
Not exactly like this but along these lines would be nice...
Subtle sloop down to the front, grab rails & solar on top, low so not to obstruct view when standing, opening window on the front of it for ventilation.
All of my halyards(& reefing) is directly above the companion way so design will be important, also don't want to be banging my head on it.
Postby KJD13 » Wed Aug 10, 2016 9:06 pm
I had a dodger on my Mark 111 when I bought her - it is a pretty simple arrangement, with 2 zipped plastic "windscreens" that can be rolled up when you want ventilation.
I would be only too happy to share a photo if someone could advise me how to upload a photo.
Kevin
Wayward Lady (a Mark 111)
Williamstown, Victoria
KJD13
Postby Sailtime » Fri Aug 12, 2016 5:04 pm
My dodger is great but makes the main sheet position tricky. My cockpit was split by the traveler and the mainsheet so I'm experimenting with moving the main sheet to mid boom and losing the traveler.. in my experience the traveler rarely gets moved from the middle anyway (which everyone disagrees with! but i still see them always in the middle.. ) and i think having a good vang to keep the boom down is good enough for sail shape.. what do people think? I've been reading up on it a bit and no traveler seems to be reasonable..
It's freed up the cockpit but i haven't sailed it yet
anyway here's some photos of the dodger and new mainsheet setup etc
shea
heres the dodger setup, you can see the mainsheet hanging off the end of the boom attaching in the cockpit - i've been jealous of THs with a clear cockpit
heading out.jpg (128.63 KiB) Viewed 8960 times
dodger needs replacing.. rips at a glance
dodger 1.jpg (590.14 KiB) Viewed 8960 times
traveler gone.. so much space! epoxy filling in holes
cockpit space.jpg (580.98 KiB) Viewed 8960 times
the problem is the sheet is contacting the front of the dodger so i have to move the boom attachment slightly forward
mid boom port.jpg (604.11 KiB) Viewed 8960 times
there was a sheet attachment already on the boom so I went to that but will move it forward a bit so not hitting the dodger
mid boom 1.jpg (509.83 KiB) Viewed 8960 times
Sailtime
Postby Arohanui » Fri Aug 12, 2016 5:18 pm
I think id prefer the main sheet traveller left alone somehow with the dodger working around it. a bit tricky though aye!
Personally i like the option of having the main traveller hard to 1 side.
Interested to see more dodger applicatons!
Arohanui
Images: 5
Postby Miker » Sat Aug 13, 2016 12:09 am
You could install a round bar traveller. This is essentially the same tube as your bow rail, fitted in an arch across the front of the dodger to the top of the coach roof. The lines controlling the car (different to a norma car) it can be led through small blocks and back to remote jaw cleats closer to the helm if need be.
Or, there are some companies who sell traveller kits for boats with dodgers. It's worth a google.....
A traveller is important for some points of sail to keep the sail shape whilst sailing off the wind, and can be used to come even closer to the wind in some circumstances.
Users browsing this forum: No registered users and 50 guests
