I have a Mk 1 I need to sell. I spent a lot of time and money on it a few years ago when I first bought it, but I'm now running a charter catamaran business on Sydney Harbour and don't have the time to play with, or maintain it.
Firstly the downsides... it needs a good clean, an antifoul and the propeller coupling on the back of the inboard diesel engine has failed. The motor itself is fine and had a lot of work done to it about 3 years ago. The engine probably needs to come out to repair the coupling and the parts are about $400. A commercial repairer will charge you about $2000-2500 to do it if you can't do it yourself. Alternatively you could add a bracket to the transom and fit an outboard. An antifoul will cost you about $1200 if you can't do it yourself.
I bought new sails from Hood Sails and a Furlex furling system for it which all cost about $5000 and they have hardly been used. At has a new sail cover, sheet winches, windows and all sorts of improvements, too numerous to mention.
Even with the problems, at $5000 it's a bargain. It's located at Parsley Bay Brooklyn, starting to be neglected and needs a new home.
A few You Tube videos showing Airborne are out there. Here's one... https://www.youtube.com/watch?v=9uX20X9ICLY
Bruce 0432 027 749
