REPLACING HEADS GATE VALVES ON A MK3
Postby KJD13 » Wed Sep 03, 2014 8:40 pm
Hi, has anyone undertaken this task? If so, how did you get access to the valves?
I need to replace the original screw down gate valves, as they are around 20 years old. However, when I inspected the valves, I noticed that the fibreglass floor of the heads may need to be cut to afford access. This would necessitate removal of the toilet and the subsequent reinforcement of the floor section, post installation of the new valves.
I was hoping that someone else had found a "work-around".
Thanks,
Kevin
Wayward Lady, Mk111,
Williamstown, Vic
KJD13
Re: REPLACING HEADS GATE VALVES ON A MK3
Postby Tales » Wed Sep 03, 2014 9:35 pm
If you unscrew the top parts of the gate valve from the body you should be able to turn the body without cutting the fibreglass.
Having said that however, mine were so tight that I cut them off and fitted new through hull fittings as well.
Postby KJD13 » Thu Sep 04, 2014 9:17 am
Thanks Tom, it certainly is a challenge - i was wondering if I unsrewed the top section, could I not simply replace this with a new top section, leaving the body where it is? This would, hopefully, leave me with new working parts and a solid body!
Kevin
Wayward Lady, Mk111
Williamstown, Vic
KJD13
Postby RodM » Thu Sep 04, 2014 12:22 pm
Taking the tap section off the gate valve will improve access. I recently replaced 6 gate valves on the Albin Vega with Ball Valves. A couple were so tight I worried I'd damage the thru hull fitting, so I carefully cut into the side with an angle grinder + thin cutting disc. The body of the gate valve then cracked open and came off cleanly.
If the toilets been there a while, probably best to take the opportunity to pull it out and fit a new pump/valve kit while you're at it. All pleasant jobs!
Cheers, RodM
RodM
Postby Phillip » Thu Sep 04, 2014 5:18 pm
Rod,
If you are replacing the valve may pay to do the whole thing and replace the hull fittings as well, good for another 20 years then :D :D
Postby RodM » Thu Sep 04, 2014 6:22 pm
I was tempted. The marine surveyor said they were fine, no leaching etc so as they were fibre glassed on inside like the Tophats, I left 'em. New engine bed, replacement motor, gearbox, new prop shaft, new brass cast prop, new new, replacement replacement... My head and wallet were reeling so I left 'em for another day:)
Cheers, RodM
RodM
Postby Phillip » Fri Sep 05, 2014 9:53 am
ouch! That's a lot of 'new' stuff. Glad I did not have to go that far, the SWMBO would have had me in all sorts of trouble! :)
Fair call Rod.
Postby genda » Wed Sep 10, 2014 5:42 pm
Ahoy Wayward Lady (i do love that name)
Kevin how is the fresh'n up going ? I had my first real sail form Willie to Sandy last week in perfect conditions it was a lot of fun
Have you dropped the mast yet if you need a hand give me a buzz and I'll see you out there
Cheers Martin
genda
