Wind generator
Wind generator
Postby Tales » Tue Nov 09, 2010 6:59 am
Has anyone any experience with this product?
http://www.jaycar.com.au/productView.asp?ID=MG4570
Looks like a good thing to me.
Re: Wind generator
Postby Shaun » Mon Nov 15, 2010 7:58 am
Hi Tom,
Have a look at www.trailersailerplace.com.au & search back through the messege forum, they had a discussion on wind generators incl' those ones you mentioned.
Re: Wind generator
Postby Phillip » Mon Nov 15, 2010 10:38 am
Shaun,
There are 52 pages in that forum :shock: , can you tell us what pages we should be looking at.
Re: Wind generator
Postby Shaun » Mon Nov 15, 2010 11:28 am
Fair point, here's a start.... http://www.trailersailerplace.com.au/fo ... php?t=5884
im sure there was another thread there also on same subject but cant find it myself
Re: Wind generator
Postby Tales » Wed Nov 17, 2010 9:33 am
Shaun.
Mmmm, 16 knots (8m/sec) not all that useful to me (moored in a pen, very sheltered).
Good point about one blade not being used all the time too so not really efficient.
The 3 blade unit mentioned is not available in Australia now I believe and if the boxed weight of 17kg is any indication of its installed weight, probably not all that practical in a small boat either.
Thanks for your research!
Re: Wind generator
Postby Dolphin » Wed Nov 17, 2010 11:46 am
G'Day Tom,
I came across a simple one you could build yourself.
http://www.macarthurmusic.com/johnkwils ... urbine.htm
The advantage of a sevonious rotor is that it is not moving around all the time trying to find the wind. A long time ago I was going to have a go at building one with a mate and I think we came across the fact that they will not overspeed as the air is deflected out of the rotors at high speed by centrifugal force. This person has also added a circuit that will convert the low voltage of the generator (4 volts) to full battery voltage (13.8V) thereby getting every last drop of power out of the wind
With a fan it can overspreed. When a highwind is forecast they apply a brake by shorting the generator terminals together. It will of course generate at night too if there is any wind. You could also run the generator as a motor and you'd never be becalmed again! :lol:
Solar panels generate full power for about 6 hrs a day.
You've got me thinking!
