Inboard Gear Lever
Inboard Gear Lever
Postby Phillip » Mon Jun 15, 2009 1:45 pm
Afternoon All,
With my inboard diesel I have a combined accelerator and gear lever.
The gear lever part is activated by pushing in a button below the lever.
My problem is that when I recently removed the engine and replaced it I
seemed to have reassembled the gear cables incorrectly so that the engine
rev's are climbing before the gear box engages :? Not very good.
Has anybody experience with this type of gear? The only good part is that
I did not touch the lever assembly so that the adjustment has to be
at the gear box or engine accelerator.
Re: Inboard Gear Lever
Postby Galini » Mon Jun 15, 2009 7:46 pm
Phillip, I have a similar remote control on my Sole diesel. There are 2 Morse cables - one for the throttle and one for gear selection (Forward, Neutral, Reverse). It sounds like your gear selection needs adjustment. On my engine there is a manual gear lever on the gear box - I set that to neutral and then adjust the Morse cable to agree with that setting (i.e. remote control lever is vertical).
I hope that makes sense, I'm describing from memory.
Gary
Galini
Gary
Galini
Galini
Postby Phillip » Mon Jun 15, 2009 11:03 pm
Evening Gary,
Yes that's what I have also.
Could you have a look at the lever on your gear box please,
because that's where I think I have reassembled it incorrectly :mrgreen: .
I think I had 2-3 adjustments at the gear box lever and any clues before I start playing around will help heaps.
Postby Galini » Wed Jun 17, 2009 9:31 am
Phillip, the way the weather is it could be a while before I visit my boat to look at the gear lever.
However, I can tell you that I have never changed the settings of the lever on the gear box, so I am no help there.
What I have done is disconnect the Morse cable where it joins the slot in the gear lever. With the remote set to neutral (so only idle revs) I run the engine and watch the prop shaft as I slowly move the gear lever forward. While the prop shaft is immobile I know that I am in neutral. As soon as the prop shaft starts to turn I back off just a little so that I am in neutral again and tighten up the Morse connection. That way I know that as soon as I nudge the remote forward I will be going into gear as well as increasing revs.
Good luck,
Gary
GALINI
Gary
Galini
Galini
Postby Phillip » Wed Jun 24, 2009 8:39 pm
Evening Gary and All,
Finally tackled this problem today.
I found that the idle adjustment on my Nanni diesel was set to high and
the accelerator cable short, so that I could not idle the engine.
Once I backed off the idle and adjusted the lenght of the accelerator cable,
I checked that the gear box went into gear before the accelerator cable took up to
increase the engine reves.
It worked :D so now the engine idles until it is in gear and then I can put on the reves!
