Strengthen spongy port fore cabin top
Postby dism » Fri Jul 07, 2017 10:50 pm
Above the galley (opp head compartment) the deck has some give in it when walking around.
Considering adding extra grab handles (mark 1) side to roof square seems to strengthen other section of deck.
Or add some carbon battens under in a triangle tied into something structural?
Anyone else done this?
Want to keep standing clearance, minimal dark areas and clutter
Azzura currently in deck/interior painting mode
dism
Re: Strengthen spongy port fore cabin top
Postby Troppo » Sat Jul 08, 2017 11:30 am
Hi Dean, have your thought about stiffening up the deck by injecting epxoy?
Windchaser had a bit of deck in almost the exact same area which seemed to get a bit spongier over a couple of years. I did a repair I was 80% happy with which is a good statistic for me : ). In retrospect I could have done things better. If you do decide to do a repair something like this I can write more about what I would change if I did the repair again.
However, the job I did, as unprofessional as it was, worked really well. Note that when I drilled the holes, I realised the wood underneath was a bit rotted but dry so easy enough to put epoxy in. Didn't need to dry it.
Here's what I did:
http://www.tophatyachts.com/viewtopic.php?f=6&t=1764&p=10791&hilit=soft+deck#p10791
And the general process on various websites:
See page 28 section 5.1.3 of the West System repair guide.
http://www.westsystem.com/wp-content/up ... l-2015.pdf
The following are just random web pages to show more ideas on the concept. I am not saying they are the best way to do it.
http://www.rotdoctor.com/projects/catdeck.html
http://www.star-distributing.com/howtog ... ation.html
This type of fix may be okay for your boat. Hope you can sort out a repair.
Postby dism » Fri Jul 14, 2017 6:23 pm
Cheers Louis
Good info. Think slightly diff issue so have laid glass over deck to strengthen now to check if successful.
Just under boom not on side near stanchions
dism
Postby Troppo » Sat Jul 15, 2017 8:42 am
Great to hear you have done a repair.
Many of my repairs were experiments. I was always learning new stuff. For me, that was part of the interest with having a boat. : )
Please let us know how it goes.
