twin batteries
twin batteries
Postby jolabeach » Wed Apr 15, 2015 7:20 pm
thinking of installing another 12v battery. the existing one is mounted in the port side cockpit hatch. wonder where other tophats place there twin batteries. i am thinking of trying to balance the weight away from the cockpit.stellar has a 10hp inboard installed. stellar is a MK111.your thoughts would be appreciated. rob
jolabeach
Re: twin batteries
Postby Troppo » Wed Apr 15, 2015 7:58 pm
Hi Rob, can't help you as I have an outboard. However, I moved my battery from the cockpit locker to under the cockpit where the rudder pipe goes through. You would have your motor where I have my battery. I have made a frame for the battery to sit on and it can take two batteries if I want to add another one.
Re: twin batteries
Postby Phillip » Wed Apr 15, 2015 10:09 pm
I have the starter and one house battery under the cockpit aft of the engine and the over house B is on the starboard side while my fuel tank is on the port side.
All balanced :D :D :D
Re: twin batteries
Postby jolabeach » Thu Apr 16, 2015 6:38 pm
thanks guys i will check it out on the weekend. it appears to me that no 2 tophats are the same just to make things interesting .cheers
jolabeach
