Forward stauncion, is it necessary ?
Postby Topi » Sat Jan 25, 2014 9:20 am
The forward stauncions have been removed by the previous owner. Common on small yachts used in bays and harbours, our E26 had them off as well.
I have the hardware, but was wondering if they interfere with the sails and hence removed ?
For coastal sailing I would like to put them back on if they are not a issue.
Topi
Re: Forward stauncion, is it necessary ?
Postby bearmcnally » Sat Jan 25, 2014 9:30 am
Welcome Topi
I'm a big believer in railing stops many things from disappearing over the side,including myself ? Yes ,stanchions and wire can hold the headsails up and crew crew has to pull them down ,it's called "Skirting"
Postby Topi » Sat Jan 25, 2014 9:47 am
Thanks Bear
Will add refastening them on to the list.
Topi
