Wire braid main Halyard
Re: Wire braid main Halyard
Postby Miker » Wed Jun 18, 2014 7:54 am
8mm is perfectly fine Mark, but it's harder on the hands when hauling it up. That's why I went for 10 myself.
As for the length, I think I bought 25 metres, as my winches are just behind the traveller on the coach roof. The extra gives you the ability to end for end it later on if there are any wear points. That being said, mine has been there now for four years, and apart from some fading of the red to a lighter shade, there is no sign of wear.
Postby storm petrel » Wed Jun 18, 2014 7:57 pm
Yes 10mm is easier on the hands, but you only raise the sails once a sail and they should go up easily. You should not have to apply much force until you reach the last few inches and this is a job for the winch. So, while I can understand oversizing the sheets, I don't think you have to worry about this for halyards unless you/ your crew have very soft hands.
Postby Anthonyb » Sat Jun 21, 2014 9:47 am
Hi Genda,
I have just received a quote for a new aluminium mast girder from an engineering firm in Ulladulla of $500.00. I gave them the old girder from my Mk1. It is being made in the next 4 -6 weeks . If you or anyone needs to have one made maybe we can get a discount with numbers ,let me know andI can contact these people.
I didnt have any luck wtih Central coast company that used to make them.
Tony
Anthonyb
Postby genda » Mon Jun 23, 2014 6:01 pm
Hi Tony and Mark
Thanks for the rely, picking up my spectra tomorrow so thanks for the heads up.
I will have a good look at the mast girder as well can you tell me when they hope to start you job if I need to co-ordinate to get one as well
Cheers Martin
genda
Postby Anthonyb » Sun Jun 29, 2014 9:34 am
Hi Martin,
I am getting a new aluminium mast girder made ASAP n the next 4-6 weeks. I gave the original girder to the engineering company to copy. Mine is a MK1 version. The company details are below
Alstain Sheetmetal
Camden st Ulladulla
02 4455 5963 / 0418 171 004
Tony
Anthonyb
Postby storm petrel » Sun Jun 29, 2014 10:49 am
Tony,
I would be interested to know what thickness aluminum they are using for the new mast girder.
