1GM10 bits needed-and advice for those with one
Postby Deepsouth42 » Fri Jul 08, 2011 7:40 pm
Greetings all
The anti-siphon box accumulates water at low revs. This is why when at idle there is an intermittent slurp of water from the exhaust. A knowledgeable mariner revs the engine prior to shutdown to clear this. The consequence of not doing this is to have seawater splash back into the exhaust port...need I go on?
Anyway I am now in need of a new head for my engine. The quote is about $900 for the unit plus the new exhaust valves gaskets etc. Not much change from $1200
Does the wisdom of the list extend to sources of alternatives?
Thanks in advance for any suggestions
tom
Yogamada
Mk1. Kettering
Deep South Australia
Deepsouth42
Re: 1GM10 bits needed-and advice for those with one
Postby bearmcnally » Fri Jul 08, 2011 8:05 pm
Hi Tom
I spent that and more on my D6 BMW (BINTROUBLE) :o . re exhaust box that's why the hose from the outlet/ back of the box can be no longer than 3.0 m (I think ? ) so when you stop the engine the water in the exhaust tube runs back into the box . And the box needs to be at least 250 mm below the head of the motor to stop it running back into the head .
Postby patrol1064 » Sat Jul 09, 2011 7:23 am
hi tom i have a think it is 1987 1gm10 might just need new rings and a oil sump but otherwise good for parts if you are intrested......cheers brian
patrol1064
Postby Deepsouth42 » Sun Jul 10, 2011 6:10 pm
Thanks for the additional advice...now I learn another hard lesson- I was worried about the anti siphon being nearly touching the spinning shaft so lifted it a little...how to kill your engine in three easy omissions :cry:
1; leave the tank half full for a few months then run the water that has condensed and gathered at the bottom of the tank through the engine
2; fail to clear the anti siphon
3; move the anti siphon up....
Oh well thems the breaks
Yogamada
Mk1. Kettering
Deepsouth42
Postby Deepsouth42 » Sun Jul 10, 2011 6:14 pm
patrol1064 wrote:hi tom i have a think it is 1987 1gm10 might just need new rings and a oil sump but otherwise good for parts if you are intrested......cheers brian
Hi Brian
Yes very interested.
can you send my your phone number by private message and we can discuss?
tom
Yogamada
Mk1. Kettering
Deepsouth42
