Tophat height from waterline to top mast
Postby Arohanui » Fri Dec 11, 2015 4:02 pm
What is the height from water to mast?
I looked on spec page but dont think that info is there. Thanks
Arohanui
Images: 5
Re: Tophat height from waterline to top mast
Postby Phillip » Fri Dec 11, 2015 9:05 pm
Yours maybe different to every body else's,
Attach a line to one of your halyards, haul it up and mark the line at the mast girder.
Measure that line, add a bit for what you have on top of your mast and the distance the girder is above water and add it all up.
Should come to around 9 metres. :D
Postby Arohanui » Sat Dec 12, 2015 6:59 am
Thank you so much Phil!
Arohanui
Images: 5
Postby Alyosius » Sat Dec 12, 2015 9:08 am
I can't give you the whole answer, but I know my mast is 9.54m from deck to masthead (plus about 20cm for the wind indicator)
I allow about 1m for deck to waterline - though really need to measure that at some point.
Long story short you can pass under the Brooklyn bridge
Galini
1981 - Mk3
Nelson Bay
Alyosius
Postby Arohanui » Tue Dec 15, 2015 9:20 pm
Thanks so much!
Arohanui
Images: 5
Postby Arohanui » Sun Dec 27, 2015 7:01 am
My mast is 10.2m
Arohanui
Images: 5
Postby Alyosius » Thu Dec 31, 2015 5:45 am
Okay.... Slight correction to my last...
Getting under the bridge is possible, but beware of high tide. I must be underestimating my overall height as I scraped my radio antenna on the bridge on the way under on Monday. It was probably about 11, so right on high tide of 1.8m.
I'll put up the whole story of my latest voyage soon but thought a correction to my original post was required.
Galini
1981 - Mk3
Nelson Bay
Alyosius
Postby Troppo » Thu Dec 31, 2015 7:33 am
Alyosius, if all you scraped was your radio antenna then all good. : )
A recent savage storm here in Rockhampton dragged a moored boat under the main bridge, which is darn high thing, but low enough that the top of the mast hit. With storm conditions, the mast ended up breaking.
I am keen to hear the rest of your story!
Postby SeaLady » Wed Jan 06, 2016 5:28 pm
I go under the bridges at Brooklyn regularly.
Always looks as if I am going to hit the mast (just as it does going under the Sydney Harbour Bridge).
Even at high tide have never hit the antenna.
1.8m high tide. I will remember that.
Users browsing this forum: No registered users and 23 guests
