Trailer for a Top Hat ?
Postby frank » Mon May 11, 2015 1:22 pm
Just toying with ideas, but would it be feasible to adapt a tandem car trailer to carry a top hat.? would it carry the weight or would a tri axel be needed? or am I dreaming.
frank
Re: Trailer for a Top Hat ?
Postby Phillip » Mon May 11, 2015 6:54 pm
need to allow for 4 tonnes.
Seaka is at Pancake Creek for 7 days due to bad weather. :D
Postby Ianb » Mon May 11, 2015 8:12 pm
It depends on the axle and tyre dimensions. From memory you might squeak in with tandem "Ford" axles, but more than likely you would need a proper rated trailer. The trailer would probably be worth more than the boat.
Postby frank » Tue May 12, 2015 8:09 am
Ianb wrote:It depends on the axle and tyre dimensions. From memory you might squeak in with tandem "Ford" axles, but more than likely you would need a proper rated trailer. The trailer would probably be worth more than the boat.
haha that's what I was thinking
frank
