wet sand blasting
Re: wet sand blasting
Postby bornfreee » Sun May 20, 2012 8:29 pm
Did a mates boat last year at the Gold Coast a Mottle 33 the shipright there came over to us and showed us what he uses it looks like a broom head with a universal joint and velcro on the end for the sand paper to grip it is called a doodle bug, and because of the broom handle it saves your back you keep the the water going on trickle and start rubbing it got years of anti foul off relitivley quickly right back to the gel coat, the thing i have against any kind of blasting is no one will give you a written guarantee how much they will take off, because it is in possible to regulate how far they go it is all on the skill of the operater so not only is it expensive but you have to except some of the good stuff will come off
bornfreee
Postby Dolphin » Mon May 21, 2012 10:33 am
Hey Rob, sounds like a great plan to me! :D
A man has to have a plan, and a boat.
Drop in at the Lake on the way round. You'd be most welcome.
Postby SeaLady » Mon May 21, 2012 2:29 pm
Rob will you please refrain from posting comments like sailing to the Whitsundays.
The jealousy from the rest of us is intolerable. :mrgreen:
Sounds like a great trip.
I would be interested in all your modifications for such a trip.
Are you going solo or with crew?
Postby rob.lovelace » Mon May 21, 2012 6:04 pm
love to drop in Greg
yes Di a crew of one on Sundowner. I've knocked out the cupboards to widen the settee into a decent size bunk and I will put on a lee board. AIS transceiver, Fleming vanegear , LED hella tricolour masthead light new solar panels bigger battery bank maybe an Ampair Aquaair charger if I have any money left. And I'll see how that goes for now.
Postby Phillip » Mon May 21, 2012 10:38 pm
Rob,
What size solar panel are you looking at and how many amp hours have you in your house batteries?
Have a look at the wind turbines on e-bay before you buy in Aus.
Postby rob.lovelace » Tue May 22, 2012 8:38 pm
Hi Phillip,
I have 2 x 20w panels and am getting a pair of 80ah batteries I have no other means of charging as yet. My current system is half this size and is only good for a few days running. I have been thinking I'd putting a alternator from the wreckers on a frame with an old brush cutter engine I have for emergency but that sounds like to much trouble. I checked out eBay and they do have some cheap wind generators eh. I'll do my sums when I have all my kit installed and see what it will take to maintain.
Postby Phillip » Tue May 22, 2012 9:14 pm
Rob,
I don't think 40watts is enough. I will try to get my usage calculated before the weekend but I'm thinking that nearer 100watts will be required.
E-Bay special: item No. 270813539185
• Max Power: 100W
• Max Power Voltage: 19V
• Max Power Current: 5.26A
• Open-Circuit Voltage: 22.8V
• Short-Circuit Current: 5.68A
• Dimension: 120 x 53.5 x 3.5cm
• Weight: 8kg
$157.00with free postage
