Whilst my son was out sailing yesterday 2 of the attachment points of the Pushpit failed on the Port side. From his description it sound like the bolts sheared. Anyway it sounds like a tricky job, as there must have been water ingress over the years and mega corrosion for this to occur. I now have the golden opportunity to remove, straighten and refit the Pushpit properly. I had noticed when I bought Night Cap that the pushpit is bent (obviously took a knock from astern on the port side). Maybe the impact weakened the bolts on this side. Has anyone refitted a pushpit? Any knowledge you can pass on will be most welcome. Also if anyone knows of a good place to take the pushpit for straightening (and any repair (welding possibly) that too would be much appreciated. Cheers, John.
P.S. The next few hours available had been allocated to sanding the coach house roof grab rails. Oh well, have to move this time to the new priority.
