Sadly Pavolova boy has decided he does not want to see me anymore. Perhaps the requirements of cooking pavlova, peeling grapes and waving palm fronds was too much to ask.
Dont worry Diana, Fondue man may still come sailing with you, but go easy on peeling grapes and waving palm fronds, he has difficulty doing more than one task at a time.
Pleased to see you are still out there 'fondue man'. How is Peppercorn going? Have you spent anything on her yet or are you still sailing on a wing and a reel of sail repair tape.
Here are some photos of Felicite's upgraded rigging. For the first time i can now get lots of forestay tension on with the double purchase on the backstay and she points as best she can. As the rigger said it needs lots of backstay on the power pole! The running part of the backstay is Dyneama.
Double purchase on the backstay
New rigging screws
Greg Felicite Mk III Lake Macquarie "After it's all said and done, there is a lot more said than done!" Aesop 620 BC
I like the storm board brackets for the windows. Someone fancied doing some serious ocean going on her at some stage. Do you have the window boards still?
Yes I do still have the storm boards. Always ready at hand. Never used them in anger. I think the windows are the one weak point on the Mk3. We did some serious cruising in 92 up to Great Keppel and back from Port Hacking. I thought we took it easy but we travelled at about the same speed as Philip. There were a couple of times we could have used them if it got worse. We're reliving the trip that Philip is doing now.
I did a trip in 83 and we were on a 43ft steel sloop that got hit with a wave first night out off Newcastle and it broke a laminated window 300 by 150 and stove it in. It was directly over my bunk. Paranoid? Not me! Greg.
My new mast is up and looking pristine. Sadly my jib does not fit the new furler so is off at the sail makers. And my radio does not work despite having a brand new aeiral and wiring. @!%$^&&*&%$#$#@^&$%E# It worked before the aerial got broken. (*(*&&^%^R%E$&*()P&*(&^%R^
Yesterday was lovely sitting in the rain and cold with my wet weather gear watching other people work.
Have a 2011 and a 1977 coin under the mast. The 2011 $1 coin cost me $13 as there are none yet in circulation so I had to buy one from a collecter.
Again @#%$&*&*(^%^$#$@
Looking forward to getting her out on the water and some warm weather.
I asked the riggers about how to get rid of the rigging in the case of an emergency. They say it is basically impossible to cut the wires they used and should the worst happen, just knock out the pins. So all I need is a hammer and a pair of pliers.
