prop size
Re: prop size
Postby bearmcnally » Thu Jun 16, 2011 5:07 pm
Hi Tom
I wrote a post last year or later regarding the difference between the Mk 1 and 2 and 3 apart from the obvious ? ;)
The mold for the Mk 2s and Mk 3s did have the deadwood scolloped out around the prop aperture? to allow more water around the prop. My father did the same when we built the battern mold for Jilpanger back in 1972 and it did help a little bit . Egret II only has a BMW 6hp in her and swings a large prop with large fan tip blades at the top to try and keep them biting as it spins. That was why I changed from a 2 blade to 3 blade on Porters advice to keep the blades from hiding behind the back of the keel ,which a 2 bladed does .Which means every time a 2 blade prop came out from behind the keel it would push the water away instead of biting the water and this caused the so called cavitation problem with 2 bladed props because the water never got a chance to fill the hole again :? .The disadvantages with a 3 bladed prop was the little loss of boat speed .
Regarding reversing? Egret II reverses like a mad cow !
Below are a few photo's of Jilpangers rudder area sorry about the quality
Re: prop size
Postby 8philip8 » Sun Jun 19, 2011 9:40 pm
my prop got losen & droped off last winter!
had no record of the size???!!!
ended up got intouch with the inboard importer & ordered one from him.13/10
didn't know the lenth of the prop sheft, the prop was a bit too close to the hull.
Chris the engieener had to reduce the prop size to 12/10 ,so it can be save to install.
8philip8
Re: prop size
Postby patrol1064 » Mon Jun 20, 2011 3:50 pm
hi all,the mk111 prop is well offset surely that would do away with cavitation,yes/no?cant get the shaft coupling off so ive decided to take off the prop and pull the shaft through the inside.waiting for the right daytime tide as no one is game to tow me around at night.too cold i guess,anyway hope the prop comes off easier than the coupling.thx for the replies....brian.....topknot.
patrol1064
