Self Steering / Windvanes
Postby Shaun » Tue Jan 06, 2009 10:42 pm
From: Paulus (Original Message) Sent: 12/6/2007 9:42 PM
Does have anyone experience with selfsteering devices such as a windvane? Can you build it your self and what is the principle based on?
Reply
Recommend Message 2 of 3 in Discussion
Hi
There are 3 main ways to go with self steering
1/ an electronic tiller pilot - easy and accurate. About $700 -$1000
for a Top Hat. It uses a bit of power so you need a way to keep your
batteries charged
2/ Sheet to tiller steering - this uses the power of the wind taken
directly from the pressure on the mainsheet or sometimes the jib sheet
, a bit complex and you need to have the boat well balanced, but very
cheap, about $50 in rubber shock cord and rope.
3/ A Windvane - The principle is a complex subject but I will have a go
at a brief overview:
There are two main parts to a windvane steering system. The wind vane
and the water vane which is usually referred to as the oar. The wind
vane can either rotate about a vertical or horizontal axis. As the
force from the wind is small on vertical axis vanes they are usually
only used on Trim Tab designs where the wind vane directly turns a trim
tab on the rudder. These designs are simple and cheap to build, the
famous yachtsman Bernard Moitessier sailed one and a half time around
the world non stop using a simple trim tab vane that he built with a
broom stick and water pipe. Unfortunately they are only practical on
boats with rudders hung on the transom so no good for a Top Hat.
Most wind vanes these days are servo designs where the wind vane turns
the oar which turns the tiller by means of ropes. The oar turns on a
vertical axis and the main problem is that the pressure transmitted by
the wind in normal sailing conditions is very small so if this rotation
is directly linked to the tiller, the vane can easily be over powered
by bad sail trim or wave action. To overcome this, most modern designs
use an oar, that not only rotates on a vertical axis but is also
allowed to rotate on a horizontal axis AT THE SAME TIME. In other words
the wind vane twists the oar out of alignment with the water flow and
the oar is pushed sideways very powerfully by the water. The sideways
movement is linked to the tiller by ropes. The side to side action of
the oar, or pendulum action, gives these designs the name "pendulum"
and the fact that they are linked to the main rudder gives them the
name "servo" Most commercial designs these days are Servo Pendulum but
where it is difficult to link the wind vane to the tiller such as
centre cockpit yachts a wind vane may have it's own separate rudder,
in which case it would be a Pendulum Servo Auxiliary Rudder System.
With pendulum servo designs the requirement to have an oar rotating on
two axis at the same time is what makes the design complex and
expensive. However, if you wanted to experiment you could build one for
less than $100. The late Walt Murray provided plans for these which are
built out of PVC pipe.
http://www.mindspring.com/~waltmur/Self-Steering/. Also if you want to
experiment with sheet to tiller steering this is a good site
http://www.solopublications.com/sailariq.htm#main
On my Top Hat I have an outboard mounted in a cut out in the transom so
I can't easily mount a wind vane on the centreline of the boat so I
bought a Raymarine ST 2000 electronic tiler pilot which works well in
the harbour but can have problems outside in large waves. Also in
addition to the main battery and solar panel I have a smaller battery
with it's own solar panel so I don't get caught without power for the
radio and nav lights.
Keith
Reply
Recommend Message 3 of 3 in Discussion
Hi Keith,
Thank you for the detailed description. I've looked at Walt Murray's website and I'll give it a go. It doesnot look too complex and I'll post my experiences on the user forum.
Cheers, Paul
Re: Self Steering / Windvanes
Postby pauldg » Sun Feb 28, 2010 9:57 pm
I recently found a web site that provides a free plan to build a wind vane steering tool.
Since the materials were a bit hard to find, I bought the kit for 300 euros from http://www.mistervee.com
Just finished the assembly and have installed it on my boat. Next step is to step is to test it out and see if it works. Also I have taken some pictures so will post them if anyone is interested.
Cheers, Paul
the wind vane installed
pauldg
Postby Marinka » Wed Mar 03, 2010 6:39 am
Hi Paul, I would be interested in having alook at your photos and finding how it works. Could you kindly email them to me on phurrey@tpg.com.au ? Wondering about cost in OZ? Thanks Peter
Marinka
Postby pauldg » Wed Mar 10, 2010 6:07 am
Hi Peter,
I'll take some pictures and post them to you. The kit cost $600 AUD which I initially thought was expensive but when I got the materials and compared the prices, it is really cheap. The wind vane mast is made of fibre glass, the vane is lexan waver, marineply wood for the rudder, stainless steel for various bits, pendulum is a combination of plastic tube clamps and glassfibre tube, carbon fibre pushrod, formica vane base, glass bearings, nylon crown bevel wheels and various marine 316 steel fittings... I probably have missed a few bits.
pauldg
Postby Phillip » Wed Mar 10, 2010 7:49 pm
Hi Paul,
I went and looked, then registered on that web site but could not download the dimensioned drawings. Seems you have to be a customer.
Is there any chance you can download them for us and post to me via my PM?
Cheers Phillip
Postby scotty » Sat May 29, 2010 11:45 am
hi pauldg
I'm very interested in how the mistervee vane performed on your tophat.
Also, was the installation complicated? Could an office worker do it?
I have been looking at this product as a cheaper alternative to the navik etc but have so far hesitated.
thanks in anticipation.
scotty
Postby pauldg » Sat May 29, 2010 4:46 pm
Phillip wrote:Hi Paul,
Cheers Phillip
Sorry Phillip for the late reply but just back from Singapore.
I think they had a glitch on the website, so try again. If possible, I'll download them and post them here.
They are an open source design!
pauldg
Postby pauldg » Sat May 29, 2010 4:49 pm
scotty wrote:hi pauldg
Hi Scott,
The installation was not complicated just a few pipes and U clams. I guess an office worker could do it (I'm a Business Analyst but have a degree in electro engineering).
The cheaper alternative is for people who like to experiment (it takes a lot of your time)
Cheers, P
pauldg
Postby bearmcnally » Sat Jun 26, 2010 7:59 pm
hope this drawing might help you with your self steering .As you can see it is a very basic design
Users browsing this forum: No registered users and 44 guests
