Standard Horizon GX2200E VHF radio with AIS.
After reading about AIS ten years ago I have been keen to have a unit onboard. What has always held me back has been the price.
Didn’t seem to matter how many times I did the sums, it always seemed too expensive for my limited application. The most useful setup seemed to be with a chart plotter which I also did not have.
Last year, friend was given a second hand Standard Horizon VHF radio with integrated AIS salvaged from a wreck. His boat was fitted with a chart plotter and once he connected it with the Standard Horizon radio he could see the AIS targets on his plotter screen.
By the time I heard about it, the current version of that radio was the Standard Horizon GX2200E. It has a small screen on the radio which displays AIS data but does not have a chart. It can, however give audio warning of ship proximity and do the calculation of closest point of approach. It also has its own GPS and gives speed over ground and can store and use 100 waypoints. It only needs one antenna which makes installation quite easy if replacing an existing VHF radio.
Mid 2016, Whitworths had this unit available but I bought one from the USA and saved about $50. Whitworths also had a Lowrance Elite 5M HDI chart plotter on special at that time which I did buy and I ended up with a system for under $900.
Getting the two to talk to each other took a little time and correspondence with both manufacturers but I am a novice in this area and others may not have this problem.
On the boat, I tend to use the AIS data on the chart plotter but to get the closest point of approach I have to go below and consult the radio. The 5” chart plotter fits the instrument panel nicely but the sounding digits on the screen tend to be too small for me to read without glasses. The chart colour shading is what I mostly use for depth information anyway so it’s not too hard to grab the glasses for the odd time when closer scrutiny is required.
I have found having a chart plotter a great advantage and prefer to sail with it switched on now that I am getting used to it. Sailing as we do in the South of Port Phillip with the tides, ferries and the ships to contend with, the AIS is a real boon.
