So Iluka is out of the water at the moment and I have decided I should check the rudder, the problem is I can't get the tiller attachment that holds the tiller to the rudder post of the shaft, the fitting is bronze and fits to the shaft with a key way pin. I've tried wd40 and a gear puller. I was thinking to try a blow torch next. Does anyone have any other suggestions?
Cheers Nick
