Excessive Weather Helm - fact or problem for the few
Posted: Tue Mar 03, 2020 10:41 pm
I have been reading the Forum and other sources of information about Top Hats, and have come across several comments that as wind speed increases so does weather helm and disproportionately so. One article I read recommended getting the first reef in the main as soon as wind speed was over 10/12kts.
While easing or reefing the main should definitely reduce weather helm, is it really the problem the article I read made it? I have been looking at a lot of photographs of Top Hat cockpit layouts,
and yes I realise she is classified as a cruising boat but let’s not forget she was designed as a racer for the JOG series. One of the things I have not seen is a Top Hat set-up with the ability to play the traveller which should/may cure the weather helm issue in gusts.
I assume this must have been tried in the past and am interested in what the results, if any, were. I am hoping to after getting used to my boat in take part in WAGS and SAGS club races which are held in Moreton Bay . I will not be removing ballast etc but naturally will be removing sails that won’t be used in that afternoon’s race, excessive food all the things that seem to find their way aboard and possibly carrying only enough fresh water for 24 hours. In other words not comprising safety but not having unnecessary items on board for the races.
If anyone has information / advice on the weather helm issue, is it as fierce as described and how did you resolve it would be greatly appreciated. I have also wondered if anyone has tinkered with rudder shapes, I wasn’t thinking or altering the tiler of rudder shaft but wondered if anyone one without an inboard engine has faired off the gap where the prop used to be and as I mentioned tweaked the shape of the rudder in an attempt to reduce the apparent fierce weather helm.
If anyone reading this is the author of the piece on the excessive weather helm and the need to reef if over 10/12 kts I am not doubting your words but simply trying to see if it is a common issue and how others deal with it.
