Jib Sheet cars
Jib Sheet cars
Postby Maggsy » Fri Jul 16, 2010 3:48 pm
Sea Monkey does not have jib sheet tracks, instead she has cars that run along the full length of the toe rail. To be exact she has one car as the other one is missing! I had a bit of a look around, but I am unable to locate a replacement, and before I get one fabricated, does anyone know where I might find one? I have tried the second hand shop in Mona Vale.
Otherwise does anyone know of a decent fabricator?
I have included a picture below.
Regards ... Maggsy (Sea Monkey)
Jib Sheet car on Sea Monkey
July 2010 008.jpg (112.46 KiB) Viewed 5688 times
Maggsy
Re: Jib Sheet cars
Postby bearmcnally » Wed Jul 21, 2010 8:06 pm
Hi Maggsy
Give Ullrich aluminium a ring they extrude aluminium toe rails and they might be able to help, or point you in the right direction.
Regards Bear
Re: Jib Sheet cars
Postby Dolphin » Wed Jul 21, 2010 8:52 pm
G'Day Maggsy,
hav eyoutried the Marine Exchange? They used to be in a shop in Sylvania on the western side but have now moved to the net only. If you email them they might be able to help.
http://www.marinexchange.com.au/
Some of the stuff is VERY second hand but someis almost new. After the Sydney Hobart they have good deals on wet weather gear and harnesses etc. I hope it helps.
