Yanmar engine - oil filter change
Postby Curryhouse » Fri Apr 20, 2018 8:26 pm
Getting prepped to do my first oil and filter change on my Yanmar 1GM10 engine. For those forum members with a similar engine, do you use an original yanmar oil filter or is there a suitable after market filter that can be used without causing any problems? Thanks in advance.
Neil
Periwinkle
Curryhouse
Re: Yanmar engine - oil filter change
Postby lockie » Fri Apr 20, 2018 9:56 pm
I have a 2GM and buy Fleetguard equivalents to the Yanmar oil and fuel filters. Do a bit of googling and you will find the type numbers. I do have them somewhere but not on this laptop. I am devoted to avoiding overpriced OEM parts where there are viable aftermarket equivalents. If you want more info on my tight arsed solutions to parts, pm me.
Cheers, Graeme
Postby Curryhouse » Fri Apr 20, 2018 10:50 pm
Hi Graeme, Had to smile when I read your comment, '....tight arsed solutions'. Exactly the type I look for also :) Will follow-up on fleetguard. If I get stuck, I'll PM you. Thanks again. Neil
Neil
Periwinkle
Curryhouse
Postby Curryhouse » Sat May 12, 2018 7:48 pm
Let my fingers do the googling and came up with a couple of equivalents from Fleetguard and Baldwin. During my searches, I found differing Yanmar PNs for the oil filter so sent an enquiry to Yanmar (in Netherlands I think). Within a couple of days, received an email from a Yanmar agent (Minards Diesel) in Newcastle confirming PN fitted to my engine. Decided to pay them a visit and ended up buying a service kit for my model engine. The kit contained oil filter, fuel filter and gasket, and water pump impeller and gasket. Likely a bit overpriced but cheaper than buying the parts individually. Will use an equivalent filter next oil change.
I can't use the Yanmar fuel filter and gasket (PNs 104500-55710 and 2431-000440). If anyone can use them, I'll send them on for the cost of postage.
Neil
Periwinkle
Curryhouse
Postby Tales » Thu May 17, 2018 1:52 pm
Hi Neil,
I can use them thanks!
Will send you a PM
