Saving your ST1000 or ST2000 from self distruction
Hi
Talking of self steering, my ST2000 failed and when I pulled it apart I found bits of rubber and other chewed up parts. Fortunately I was able to get it going again with some grease and epoxy minus a few bits, it’s a bit wonky but what the hell, two years later it still works. Unfortunately there are a few parts that are seriously degraded and it’s only a matter of time before the unit fails. The total cost of all the parts I need are about the same as the cost of a new ST2000. So how do I save my new unit (if I get one) from self destruction? Because as everyone who owns one knows, the problem with both the ST1000 and ST2000 is that once the push rod is fully extended or retracted the motor is still engaged and until the boat comes back on course the push rod will be forced hard up against it’s stops with the motor going berserk. This is no problem on a power boat because it will never be that far off course but on a sail boat, no matter how well balanced, situations occur when the push rod is hard over. Eventually the motor burns out, the belt drive breaks or the ST just eventually tears itself to pieces. My ST2000 seems intent on doing the later. I was giving some though to this problem when I came across the following modification:
http://www.cruisingonstrider.us/ST1000mods.htm
The purpose of the modification is to ensure that when the push rod is hard over the motor will be turned off with the push rod in the (unpowered) hard over position until the boat comes back on course. This is accomplished with a cunning arrangement of only two micro switches, and two diodes and a spring. There are no complicated electronics involved but the mechanical mount of the switches would take a bit of skill.
Really, Raymarine should have fixed this problem years ago (or maybe they have? my ST2000 is 9 years old). Or Maybe Raymarine are happy to have these units fail so they can market their more expensive units?
BTW Webb Chiles killed 3 autopilot during his trip from the USA to NZ in his Moore 24. For the remainder of his solo circumnavigation he has installed what appears to be a vastly superior Pelagic unit.
http://www.inthepresentsea.com/the_actu ... h-ups.html
This is a unit with a seperate below deck gyro controller with remote operation. I was surprised by the reasonable price, $USD 320 for the tiller drive and $USD 780 for the gyro including a remote.
http://pelagicautopilot.com.
By contrast, locally, Whitworths advertise the Raymarine EV 200 Gyro unit for a sailboat for $3899 and if you want a handheld remote (looks similar to a car remote) it’s an extra $529! Thats a total of $4428 AUD for Raymarine VS $1100 USD for the Pelagic system.
Keith
Keith
