wind turbine
wind turbine
Postby sam » Sun Nov 16, 2014 7:57 am
has anyone tried to mount a wind turbine on a top hat?
sam
Re: wind turbine
Postby Phillip » Sun Nov 16, 2014 5:01 pm
Looked at it but the returns, weight up high and noise generated did not equal the simplicity of a solar panel.
Always have sun but sometimes no wind! :roll:
So far the 100w panel I have keeps the 3 batteries I have fully charged.
Re: wind turbine
Postby rob.lovelace » Sun Nov 16, 2014 9:32 pm
don't be dropping yo anchor near me if it's fitted. :lol:
Re: wind turbine
Postby Phillip » Mon Nov 17, 2014 4:02 pm
I'm with you on that Rob :roll:
Re: wind turbine
Postby sam » Fri Nov 21, 2014 10:44 pm
Okay so perhaps I wont bother fitting one then, I dont 'need' more power buts its always nice :)
sam
Re: wind turbine
Postby lockie » Sat Nov 22, 2014 8:07 am
One cheaper low-hassle option, if you have a diesel, is to fit an external regulator to the alternator. This will allow it to charge your batteries much faster, and to a much higher level, than the standard built-in automotive regulator. It will very effectively supplement a decent solar array.
Google the Sterling one, which costs a few hundred dollars. You will need some electrical smarts to install it, or can take your alternator and the regulator to a marine sparkie.
Cheers, Graeme
Re: wind turbine
Postby sam » Sat Nov 22, 2014 10:35 pm
hmmm, if only I had a diesel... I do have a wind turbine that I used when I lived in a shack for a few years down in victoria, its now doing basically noting, so const is pretty insignificant, but I here you with the noise thing.
sam
