Engine mounts/Fuel Line
Postby jjvvss » Sun Jul 14, 2013 9:07 am
Just replaced all engine mounts on Sole Mini 2. Ended up being a lot less stress than I thought it would. Much happier engine, boat and owner. Removed the leaking gate valve and replaced with ....nothing. Just joined the two ends together with a double female stainless tube. Where the gate valve was placed made it impossible to turn off in case of fire so pointless. Now to fix the manual bilge layout. :)
SV Petasus
Townsville QLD 4810
jjvvss
Images: 1
Re: Engine mounts/Fuel Line
Postby Ianb » Sun Jul 14, 2013 10:35 am
Maybe the valve was there to aid filter change and minimize air bleeding.
Postby jjvvss » Fri Jul 19, 2013 9:29 am
More than likely. Nothing a little plug couldn't do. And the leaking has been stopped for $2.90 rather than a new ball valve at considerably more.
SV Petasus
Townsville QLD 4810
jjvvss
Images: 1
